Aerostar Ford Aerostar
headlights
Old Feb 19, 2003 | 10:02 PM
jrktms5's Avatar
jrktms5
headlights
what cct does the DTRL us is it the HB or Lb
Problem is i have no DTRL and no LB but HB works with no indication on the dash
is this an indication that the DTRL relay modual is going.
both LB are out
any ideas
TX
Old Feb 21, 2003 | 04:59 PM
rebocardo's Avatar
rebocardo
headlights
I had to read that message four times before I got it
Gotta love acronyms!
Before assuming the day time running light module is bad, I would check to see if the headlamp sockets are receiving power on both high and low beam.
Then check the relay and the headlamp switch. Been a few years since I took my Aerostar steering column apart, but, I think the harness connector is there so you can test for power with a small probe.
Old Feb 21, 2003 | 06:20 PM
jrktms5's Avatar
jrktms5
headlights
TX for the reply
That's mayb y i don't have many responses lol..only the smart 1's
What my problem was that both LB HL were burned out which i had replaced with Zexon super whites due to the fact that the HL suck.. this was b4 Xmas. got a refund on them but i found out that eurolite sells a 100/80 watt bulb now i wondering if i use these bulbs will it burn out my DTRL modual or wiring harness due to the curent requirement and or the heat made.
No 1 knows for sure so i think i'll get a set of driving lights
mark
Daniels54
Sep 23, 2016 05:14 PM
majsservices
Jan 1, 2016 11:04 AM
pitrow
Sep 8, 2015 09:07 AM
BigGreenEx
Testing.....
Sep 8, 2014 11:46 PM
OldBronco
Escape & Escape Hybrid
Mar 22, 2008 09:21 PM
