1995 explorer shift delay
Old Feb 19, 2003 | 09:55 PM
zlatko's Avatar
zlatko
Unhappy 1995 explorer shift delay
when put in D there is 1.8 - 2 second delay. Shift is very smooth (you can barely feel it). Transmission service done but no change.
What could be wrong?
Old Feb 19, 2003 | 10:43 PM
70f100longbed's Avatar
70f100longbed
How many miles are on it? Does it do it when hot? Is the fluid full? Prob the seals are hard letting pressure go past them. Pour a half pint of brake fluid in it and save for an overhaul. The brake fluid will swell the seals.
Old Feb 20, 2003 | 06:59 PM
zlatko's Avatar
zlatko
there is 106800 on it. fluid is full. It does it cold or hot. Do you mean put brake fluid in trans?
Old Feb 20, 2003 | 07:23 PM
Billy177's Avatar
Billy177
you will probrally need a rebuild very soon
run a bottle of
this through it
Old Feb 22, 2003 | 06:00 PM
70f100longbed
Yes I meant put brake fluid in the trans. I does the same thing all those trans conditioners do. One half pint should do the trick but it's only temporary. Start saving for an overhaul.
Old Mar 4, 2003 | 07:57 PM
CNTHOR's Avatar
CNTHOR
up to the top
