96 exlporer trans. problem
Old Feb 18, 2003 | 06:20 PM
weirton57's Avatar
weirton57
96 explorer sport 4.0 4x4
At the first startup in the morning,when you put in drive (D).all
it does is rev. It takes a few seconds to go into gear.Reverse
is fine.Its worse in the winter time. Its been this way since i had
the fluid and filter change(its the second change).First at 35000
second at 67000.Last one was in July 02.Yes its been doing this
for 6 months.Worse in the winter. Any idea what it could be. other than that the transmission shifts smooth
THANK YOU
Old Feb 20, 2003 | 10:14 AM
1explorer's Avatar
1explorer
This happen to mine 2. It takes a couple seconds to kick in gear even from a stop. But once the car warms up it goes away.
I am interested to find out what might have cause this and what can i do to eliminate this situation.
Old Feb 20, 2003 | 10:39 AM
1explorer's Avatar
1explorer
Old Feb 20, 2003 | 04:39 PM
weirton57's Avatar
weirton57
with all the members here nobody knows the answer
Old Feb 20, 2003 | 07:08 PM
Billy177's Avatar
Billy177
did you use the recommended fluid
the level is probrally a little low also
Old Feb 21, 2003 | 01:54 PM
weirton57's Avatar
weirton57
the fluid and filter change was done by ford dealer.
back in july 02 thats when the problem started.i I checked
the fluid last month and its still full and red.
can anybody help solve the problen PLEASE.
Old Feb 22, 2003 | 04:33 PM
weirton57's Avatar
weirton57
One more thing...it won't do it for the rest of the day
Old Feb 22, 2003 | 05:57 PM
Billy177's Avatar
Billy177
get the fluid changed again
Old Feb 22, 2003 | 06:32 PM
weirton57's Avatar
weirton57
the fluid is clean ... why should i do that ...thats not the problem
something else is, WHAT IS IT
Old Feb 22, 2003 | 06:51 PM
CNTHOR's Avatar
CNTHOR
"With all the members here nobody knows the answer"
Did you read all the posts or are you waiting for somebody to find you and tell you the answer?
The Explorer transmissions are notoriously weak. When you got your fluid changed did you have all the fluid flushed out or just the pan dropped? If you are not sure then I bet you only had the pan dropped.
I had the same symptoms on my '95
I had the fluid changed at 30,000 (only dropped the pan)
I had the fluid changed at 60,000 (only dropped the pan)
I had the same shift problem you describe (wouldn't shift into D for a few seconds when cold).
The tranny blew it's second gear completely at 84,000. costing me about 2,400 to rebuild
12,000 after the rebuild I had a problem where the trans wouldnt shift into second. the rebuild shop gave me a bunch of bull about needing a new computer.
After that I READ ALL THE POSTS regarding the explorer transmissions.
I took the car to PEP boys and had the fluid flushed again and the trans shifts fine now.
Make sure you have the right type of fluid. I think in 97 they switched to MERCON V (instead of the older type of MERCON)
You might also think about AMSOIL synthetic fluid
Make sure you have the fluid flushed completely. also have the throtle body valves retorqued to proper tightness. have an auxiliary cooler installed inline with the original
Old Feb 22, 2003 | 07:13 PM
weirton57's Avatar
weirton57
THANK YOU VERY MUCH (CNTHOR)I'll try what you said. Its a shame you can'nt trust your dealer!!
Old Mar 3, 2003 | 06:32 PM
weirton57's Avatar
weirton57
I APOLOGIZE TO BILLY177, CNTHOR AND TOO ALL ON THIS FORUM
I would never of thought that changing the fluid and filter again would solve the problem (but it did ) and it only cost $65 to do it.
THANK YOU VERY MUCH and again I'm truly sorry for being an
A**HOLE
Old Mar 3, 2003 | 09:45 PM
CNTHOR's Avatar
CNTHOR
We're just glad you got it fixed. the dealers and transmission shops are all rip offs.
Ford did a good job with these vehicles. they are easily serviceable and repairable. it is just that the dealers don't want to fix anything for less than 1,000 and they all do a SH**ty job
The transmission shops all want 3,000 and they only do slightly better
Old Mar 4, 2003 | 07:54 PM
CNTHOR's Avatar
CNTHOR
up to the top
Old Mar 4, 2003 | 09:30 PM
ford_tr_man's Avatar
ford_tr_man
i had the same prblem in my old 95 chevy s-10 blazer(the truck i oew my life to)i had the fluid changed then it started not goin in to gear right away and it was shifting very odd so i brought it back it turns out when they changed the fluid they broke the new filter and dident put it in correctly they fixed it and dident have any problems untill i toatled the truck
Blacknav
25
Sep 20, 2015 07:38 PM
Hoosier 7.3
Jul 3, 2015 11:07 PM
luke123
Dec 27, 2010 11:23 AM
fellro86
Iowa Chapter
836
Apr 1, 2010 07:27 AM
spikeddie
Aerostar
103
May 19, 2007 07:35 PM
