AC problem
Old Sep 15, 2010 | 07:38 AM
clintusaf's Avatar
clintusaf
AC problem
Im trying to diagnose my a/c problem. It does work about 75% of the time blowin nice cold air. When its really hot outside, i notice every once in a while it will stop blowing cold air. When this happens, i notice a change in the smell of the air coming from the vents as well. Lately, its been happening more often. I took it to a buddy of mine do a pressure test and he added some freon, but no change after that. I'm lookin for any suggestions since its still ***** hot here in loiusiana.
Old Sep 15, 2010 | 07:51 AM
onelionhunter's Avatar
onelionhunter
try this
Give this a try, it fixed my random AC issue this spring
SpringerPop's Compressor Clutch Air Gap
Old Sep 15, 2010 | 08:06 AM
damons's Avatar
damons
This is good info, I think I may have to do this myself, thanks for the info.
Clint, you will have to let us know if you did this and what the result was.
Old Sep 15, 2010 | 08:15 AM
onelionhunter
Multiple fixes
I beleive a dozen or so folks have done that fix this summer alone. It didn't work for Chris(F350-6) if I remember right, he had to replace the clutch pack, but its a cheap easy place to start. Ed sells the shim kit for like 13 bucks, but even the thinnest spacer in the shim kit needed to be ground down to get my air gap correct.
Old Sep 15, 2010 | 08:19 AM
clintusaf's Avatar
clintusaf
Well, i'll definitely give it a try. After reading pops symptoms, it sounds like my problem. I'll give an update when i get her fixed.
Old Sep 15, 2010 | 02:19 PM
clintusaf's Avatar
clintusaf
I looked on Ed's site for it, but couldnt find it. Anyone got a linky?
Old Sep 15, 2010 | 02:52 PM
onelionhunter
Part number
F1VY19D648A should be the part number, 13 and some change</pre>
Old Sep 15, 2010 | 04:10 PM
izzybird's Avatar
izzybird
There should be a shim in there already, just grind it down if you have the means and you won't have to buy any. I got a shim pack from the stealership a long time ago and all the shims were thicker than what was already in there except one, seems like alot of $ for one shim that wasn't thin enough anyway.
Old Sep 15, 2010 | 06:09 PM
SpringerPop's Avatar
SpringerPop
This is the first of a double post!
See below.
Pop
SpringerPop
The part number and thicknesses of each shim are detailed on my web page, linked above in Post #2.
I also make note of the fact that they are kinda pricey for what they are!
Shim packs are for those who can't innovate!
Pop
blueeyedfordguy
1997 - 2003 F150
Sep 1, 2013 03:52 PM
jeffrey5679
May 8, 2013 09:29 AM
Jtac80
May 15, 2012 04:39 PM
PowerstrokeDude
Sep 21, 2006 10:28 PM
cmuse
Aug 4, 2004 05:34 PM
