Electrical short
Old Sep 17, 2010 | 03:15 PM
Scifi266's Avatar
Scifi266
Sounds like both could be separate problems. Have you checked the speakers for the wires being plugged in fully? I've had one speaker come unhooked and ground out and sound would go away but the radio held power. I've also had speakers ground out on the gas tank (had two speakers in the middle of the seats) so I would check with that if they're mounted somewhere that they could ground out.
For the engine just "switching off" have you made sure that all the wires are all tight against the coil? I was having intermittent starting and running problems with a loose coil wire.
Also, when the sound goes off does it make a pop or go silent?
Old Sep 17, 2010 | 04:41 PM
jowilker's Avatar
jowilker
Originally Posted by OldHarley
John,
Me and a few of the guys will be holding an all night prayer vigil down at the shop in hopes that the powers that be will drive out the foul demons from your wiring harness.
Glory to God! Thank You Jesus. I'm down with that. You think I ought to apply anointing oil?
Scifi266, The speakers slowly go out and back on sometimes slowly, sometimes like today rapidly. Just off & on no popping. Coil wires are snug.
John
Old Sep 20, 2010 | 02:33 PM
jowilker's Avatar
jowilker
I pulled the Petronix Flame Thrower coil today, I hope this is the cure.
OldHarley, Keep on praying, I haven't made a test run yet.
John
Old Sep 22, 2010 | 03:13 PM
jowilker's Avatar
jowilker
It was not the coil.
More suggestions?
John
Old Sep 22, 2010 | 05:56 PM
Scifi266's Avatar
Scifi266
Hmmm, well you said that you patted down some wires and that it worked. Have you gone through any of those wires and checked for bare or loose wires?
Old Sep 22, 2010 | 06:53 PM
jowilker's Avatar
jowilker
Hope to do that this weekend.
John
Old Sep 22, 2010 | 08:34 PM
OldHarley's Avatar
OldHarley
JW,
I guess you see why I only get $5. for my answers. ;-)
Old Sep 24, 2010 | 10:41 AM
jowilker's Avatar
jowilker
I go out to start the truck this morning and move it to the shade. I hit the switch and it turns over a few times, I pump the gas it fires up runs a few seconds and off like a light. Re-fire it revving to about 2200 rpms 5 or so seconds off like a light. Fire it a third time, put it in gear and 15 ft. it shuts off. Re-fire it holding about a 2500 idle for 20-30 seconds move it farther forward and back up 25 ft.
The only thing I know to do now is try unplugging and re-connecting connections.
A couple days ago I drove it on a 40 mile trip. It shut off several times while it was cold but once I got it running on the road it stayed running.
So it is acting up more when it's cold this week. Not so a couple weeks back.
Suggestions where to look next?
John
Old Sep 25, 2010 | 02:22 AM
Scifi266's Avatar
Scifi266
honestly, sounds like a grounding problem. Out like a light would seem like it hits the ignition, though you said you checked it. Try it with lights on when it dies and see what happens to them. Do you have a good engine to body ground?
Old Sep 25, 2010 | 04:16 AM
jowilker's Avatar
jowilker
Well I thought so. I do have a project of adding more grounds around the truck that I know I will get around to one day. I owned a 92 for a short period a few years back and couldn't believe the ground straps all over the truck.
What makes it hard to find is it's not like a bad idle that you can adjust out. It'll be running just fine and shut off, sometimes it will re-fire very quickly, other times not. You never know how long it will run. I will knock off in the yard or 2 miles down the road.
It does seem that once it passes a point (that is not the same) it runs with no problem. Morning runs seem to be close to home, afternoon further away.
With the tach jumping around the other day, I'm with power supply to the coil.
Thanks for the input.
The temps should be coming down here a bit next week so I will be more inclined to work on it.
John
Old Sep 25, 2010 | 11:49 AM
jowilker's Avatar
jowilker
Took the truck on a 25 mile round trip job today. Drove it about 5 miles out and it shut off, I don't have neutral safety switch engaged so while still rolling I bumped the starter and it re-fired.
Coming back 3 1/2 hours later and in site of where it shut off outbound it shut off again. I turned the switch off and back on and it caught and drove home.
I may pull the switch next week spray it down good with WD40 and re-attach it.
John
RomanDesign
Feb 2, 2015 08:22 PM
brzehentmaier
Jan 23, 2014 02:26 PM
Christof13T
2004 - 2008 F150
Feb 12, 2013 10:01 PM
Pkupman82
Dec 26, 2009 10:39 AM
Nogura
1997 - 2003 F150
Mar 12, 2009 09:49 PM
