Under-bed Hitch
Old Sep 14, 2010 | 11:50 PM
F350inExile's Avatar
F350inExile
Under-bed Hitch
I have a 2008 F350 Extended Cab SRW Long Bed. Does anybody make a under-bed hitch for a 5th wheel (15K) so that I can slide in a truck camper (Cabover) on after removing just the hitch?
Old Sep 15, 2010 | 12:46 PM
TexasRebel's Avatar
TexasRebel
how much clearance between camper and bed?
have you looked into a B&W?
Old Sep 15, 2010 | 08:58 PM
F350inExile
Thanks about the B&W. It looks like the 1100 would fit the bill.
Old Sep 15, 2010 | 11:09 PM
TexasRebel's Avatar
TexasRebel
the 1100 will get you to a gooseneck, but you'll also have to pick up a Companion to make it a 5th wheel.
If you don't plan to pull any gooseneck trailers, you wouldn't even have to install the safety chain hook points (5th wheel trailers don't use them).
Old Sep 22, 2010 | 11:09 PM
snorindad's Avatar
snorindad
you can also get an adapter that is rated to 24K to convert your fifth wheel to gooseneck and it will work with the B&W turnover hitch 5th Wheel Adapter.
NapaRick
Apr 17, 2014 09:29 AM
Champ198
6.7L Power Stroke Diesel
Aug 22, 2010 09:04 PM
sweetjustice
24
Jan 4, 2010 04:31 PM
dcbullet
Sep 1, 2008 10:36 PM
DOGINIT
All Things Towing
Nov 14, 2004 09:35 PM
