Water Pump Pulley
Old 09-14-2010, 04:13 PM
BigAlsPSD's Avatar
BigAlsPSD
BigAlsPSD is offline
Water Pump Pulley
Today my water pump pulley broke off? No one local has one, so I will probably order one up from Ed. My question is, I need to drive the truck about 5 miles to get it home? Rather than R&R on the side of the highway. Would anyone recommend otherwise, to have it towed or such? Temps are really nice last few days, in the 60's just curious about the internal parts, since the water pump will not be driven. And another thing, wow these trucks are hard to turn and brake without power!! The break was a little odd to me? All of the bolts are still tight and mounted to the water pump with small pieces of the pulley still being held on. The pulley is not rusted through, and appears to be in good shape otherwise? It sits flat on a bench and quick eyeball measurement it does not appear to be out of round. Just a fluke thing I guess? Hopefully this is not caused by my issue with the "shudder" at low throttle input.
Old 09-14-2010, 05:46 PM
big poppa's Avatar
big poppa
big poppa is offline
Firts time hearing that but others here might. Seems like a valid question, our trucks do have great cooling capabilities, I wonder if you could limp it home quickly.
Old 09-14-2010, 05:47 PM
mongo75's Avatar
mongo75
mongo75 is offline
That's really odd, never heard of it happening myself, and if you can break it, I've probably done it already LOL. I would not drive it myself- if you need to break, and can;t fast enough, you're on the hook for a nice negligence lawsuit. The truck will run cool enough, but the brakes would concern me. These things stop about as fast as an ice cube on a greasy hill without power brakes.
Old 09-14-2010, 06:02 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
2C3Z8509AA (replaced > > F81Z8509AA) .. Waterpump Pulley / Original pulley marked: F81A-8509-AA
MSRP: $79.57 // FTE Ford Dealer Parts Dept sponsor PARTSGUYED.COM price: $57.29.
No dealer in AR or OK has any. Closest sources to Rogers AR that have any, are in Hutchison KS and Kansas City MO.
Old 09-14-2010, 06:03 PM
BigAlsPSD's Avatar
BigAlsPSD
I did choos to drive it fyi, temp never even moved really. No fun with the steering brakes sucked but got the job done. My main concern was with the internal cooling? not pumping through the engine, hopefully everything is ok.
Old 09-14-2010, 06:07 PM
BigAlsPSD's Avatar
BigAlsPSD
I saw Ed's price, Rock auto has them $43 I believe, seems a little ridiculous for what it is? Simple pulley, before I pull the trigger on new, Im going to check out a few builders lots.
Old 09-14-2010, 06:22 PM
NumberDummy
Before buying from Rock Auto...for 43 bucks, you have another option.
The original part number (it's now obsolete because it was replaced by: 2C3Z8509AA) of F81Z8509AA = MSRP: $29.57 !!
JIM PEACH MOTORS in Brewton AL has ONE = 251-867-6212.
LINCOLN LACY MOTORS in Malden MO has ONE = 866-890-5816.
If you're thinking of buying it from another source, might as well be gen-u-ine Ford instead of a pulley that might be made in China.
Aftermarket sources might be cheaper, but where do most of their parts come from? The Orient.
Old 09-14-2010, 06:39 PM
BigAlsPSD's Avatar
BigAlsPSD
Wow thanks for that, I appreciate the replacement PN info.
Old 09-14-2010, 11:05 PM
Bdox's Avatar
Bdox
Bdox is offline
If I understand the way it broke, my bet is that the belt was over-tightened for a long, long time and it fatigued the metal.
Old 09-14-2010, 11:16 PM
BigAlsPSD's Avatar
BigAlsPSD
What would cause it to be too tight? Tensioner idler and belt are all about 1 year old? I guess prior to this it could have fatigued? But the reason for replacement of the tensioner was loose belt.
Old 09-14-2010, 11:59 PM
Bdox's Avatar
Bdox
Bdox is offline
I don't have the answer for sure, but I would take a long look at it when you install the new one just to be sure.
bulla
38
07-16-2019 03:02 PM
Drlittle
06-05-2017 11:34 PM
Icefan71
1997 - 2003 F150
04-11-2017 04:39 PM
Sam's1967
04-11-2017 12:43 PM
HT32BSX115
15
02-16-2016 03:24 PM
Quick Reply: Water Pump Pulley
