Earlier this summer I had trouble with my dual mass fly wheel (story here). when the truck came out of the shop with the replacement, it also had acquired a very noticeable new noise. The transmission is a standard and the truck has about 230k miles.
The sound is what I would call a rumbling/growling sort of sound. It is only detectable when the truck is in neutral with the clutch NOT engaged or when towing under a load and the engine starts to dog down a bit, say below 1500 rpm or so. Engage the clutch the sound goes away, increase RPM, the sound goes away.
The transmission has been taken out and partially disassembled by a different local mechanic. He couldn't identify any bad bearings in it. I saw the tranny while it was apart, it looked pristine- nothing beat up that I could see at all. What should my next step be? The consensus is that this is a transmission issue, should I be 100% convinced of that or is it possible that the new flywheel is contributing? Another argument is that the sound was there all along and I just hadn't noticed it. If it was present before the flywheel episode I am certain that it was of a much lower intensity. So what do you think?
I depend on this truck and really dont want to replace the entire transmission if I can avoid it.
Its a normal thing. Nothing wrong. You can always dump in an extra qt of atf to help quiet it down.
mines went almost completely away.
So I am to gather this is a common outcome seen when switching out the flywheels? I swear I should start a book listing all the things that everyone else seems to know that I don't. Still, would have been nice if the diesel mechanic had given me some warning about it....
your tranny will get used to the sound give it a couple thousand miles, the gear roll over will be almost or completely gone in neutral, but slowing down that growl wont go away. after a while you wont really notice it. it will quiet down a little bit.
Are there any potential issues from adding extra fluid? After Googleing the term gear roll over, I came across references to adding Lucas Transmission Fix; is that a good idea?
