6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Coolant testing
Old Sep 14, 2010 | 07:37 AM
crock's Avatar
crock
Coolant testing
I read some where lately that we should be checking the coolant to see if it weak. if too weak it could result in cavitation in the engine . Can any one verify that this is needed?
This is for the 6.4 engines,
Thanks,
Bob C
Old Sep 14, 2010 | 08:34 AM
senix's Avatar
senix
Every 20K you should be checking the nitrates. Anything under 800 ppm needs the additive, below 300 ppm you need to do the flush and clean procedure.
I don't have access to it right now if no one posts it then I will later this evening.
Only place I have found for the test strips is NAPA.
Old Sep 15, 2010 | 05:25 AM
senix's Avatar
senix
Customer info sheet about maintance
Here you go.
File Type: pdf
Old Sep 15, 2010 | 10:16 AM
hlozano's Avatar
hlozano
After reading this I called my local dealership to ask them for test strips. Went over to pick it up and to my surprise they didn't charge me for them. I thought huh?.....
Old Sep 15, 2010 | 11:55 AM
senix's Avatar
senix
check your coolant cold....or luke warm at most.
Old Sep 15, 2010 | 01:50 PM
crock's Avatar
crock
Test Strips
Thanks for the reply's. I talked to my parts man, he asked the mechanics at his dealship and they know nothing about them. I really do appreciate the info.
Bob C
StanleyZ's Avatar
StanleyZ
Interesting that is in the ESP but to my best memory it is not in the owners manual. I don't think I would have missed it. As a former 7.3L owner I'm very familiar with testing coolant. But, cause I'm old and because I've killed billions of brain cells over the years I'm going out now and look.
Old Sep 15, 2010 | 01:53 PM
senix's Avatar
senix
Was not in the manual, was a piece of paper Ford had sent me in the mail.
Those brain cells went to heaven to be with the ones I have lost too.
Old Sep 15, 2010 | 02:15 PM
StanleyZ's Avatar
StanleyZ
I guess since I didn't buy my truck new, they didn't send me one. I'll just steal yours and print it out. Thanks.
Old Sep 15, 2010 | 08:11 PM
hlozano's Avatar
hlozano
I have a question about the whole coolant thing I hope you guys can shed some light on. I was telling my buddy this evening about checking the nitrate level in his coolant. He says why? According to him when he had his 7.3 it was necessary to check the nitrate level because his 7.3 had the green coolant. According to him this was necessary with the green coolant because the chemistry of the coolant caused cavitation if the nitrate level wasn't right. He says this is why Ford switched to Gold because the chemistry of the gold coolant is different therefore the need for testing and adding the vc-8 was no longer necessary. I didn't want to get in a debate with him because he's been driving diesels way longer and is more knowlegeable. He said there's even a youtube video where vc-8 was added with the gold coolant and caused geling.
Old Sep 15, 2010 | 08:14 PM
senix's Avatar
senix
I agree with him on those points.
What I think Ford found though was over time the coolant will loose its effectiveness. So this nitrate level will tend to drop over time.
So either test every 20K or...don't run your coolant to 100K.
Bob Ayers
1983 - 2012 Ranger & B-Series
Oct 14, 2023 07:58 PM
Bob2626
Sep 27, 2011 07:15 PM
ubereal2
Missouri Chapter
Mar 31, 2007 08:01 PM
bhearn
1997 - 2003 F150
Jan 25, 2005 11:22 PM
Lightning Bob
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Feb 13, 2001 10:10 AM
