Sponsored by: Real Truck
Steering issues
Old Sep 14, 2010 | 06:45 AM
gblaz123's Avatar
gblaz123
Steering issues
I have a 2000 F350 and have issues with the hubs not disengaging. I checked the vacuum at the hubs and everything looks to be working ok. Passenger side is the one thats not working. can truck be driven without the hubs installed to test the steering?
Old Sep 14, 2010 | 08:17 AM
thomabb's Avatar
thomabb
What is leading you to the hub not disengaging? What are you experiencing in the steering? I can drive my truck in 2wd with the hubs locked with no steering issues.
Old Sep 14, 2010 | 08:22 AM
gblaz123's Avatar
gblaz123
when I jack the front end up the passenger side hub will not disengage all of the time. Driver side also seems to take a while to disengage
Old Sep 14, 2010 | 08:41 AM
thomabb's Avatar
thomabb
Have you ever taken those hubs apart and cleaned/greased them? It's not real difficult to do, you just need to be careful to get them together the same way they come apart.
How is this affecting your steering?
Old Sep 14, 2010 | 08:44 AM
gblaz123's Avatar
gblaz123
yes i just did that over the week end. What happens is only one hub is unlocked and when you turn wheel it wants to jerk back and forth.
Old Sep 14, 2010 | 09:39 AM
thomabb's Avatar
thomabb
You may have more than one issue. Check to see if the U-joints on the axle behind the hubs are binding.
Old Sep 14, 2010 | 10:57 AM
gblaz123's Avatar
gblaz123
I did look at the u joints they seem fine. Do you know if I can run the truck with the hubs removed? this would answer alot of questions.
Old Sep 14, 2010 | 11:42 AM
thomabb's Avatar
thomabb
I know you can do it with the manual hubs. I have done it myself.
Old Sep 14, 2010 | 11:57 AM
gblaz123's Avatar
gblaz123
Manual hubs will be what goes back on if these ones are bad.
porthole
6.7L Power Stroke Diesel
15
Dec 21, 2015 07:31 PM
RTFMAce
May 7, 2011 03:12 PM
focusdriverlx20
Feb 13, 2011 09:21 PM
stimmie78
Bronco II
13
Apr 14, 2009 05:04 AM
