F-1 F-2 F-3
I do st@ 2b corrected!
The only parts that are the same are the cab/doors, hood, grille, front axle, and steering box/column.
The F2/F3 to F1 conversions have been attempted by many, but completed by few.
If you want an F1, then I suggest you find yourself one. You'll be miles ahead on your project. Lastly, F1 parts are easier to come by than F2/F3 specific parts. Try finding a good F2/F3 bed....
BZZZT. Wrong! Actually, the F2 was a light 3/4 ton, the F3 a heavy 3/4 ton, and the F4 a tonner. That is why, in 1953, the 3/4 ton was designated an F250, since it spanned the two previous 3/4 tonners, and the tonner was the F350 since it spanned the F3 and F4, or so I've read. The F1 was simply made into the F100 since there was no overlap in this range.
Well I think the part of the whole discussion that may make it confusing is that the vehicles were not ever documented as half ton or one ton, etc. They are rated by their gross vehicle weight rating.
And that's not that easy either. Why, because the GVWR was heavily dependant on tires. For example the F3 had a 1200 pound - that's more than a half ton of GVWR variance (on a "Heavy 3/4" ton or "One ton" truck) - just between different types of tires!
Now logically one would think that you could just subtract the curb weight of each vehicle from the GVWR, and come up with the payload rating, and call it a "half ton" right? Well the math doesn't work. In that case each of the vehicles will carry almost half again as much cargo and the payload rating at "half ton," "one ton," etc, and stay within it's GVWR.
For example, the F1 (1/2 ton truck) is actually 3/4 ton rated. With the 6.50x16 tires and a GVW rating of 4700 pounds the F1 with a V8 has a curb weight of 3260 pounds - for a net cargo weight capacity of 1560 pounds. That's over 3/4 ton - even in Canada.
Here are the GVWR Specifications for the 51s. The other years 48-50, and 52are going to be VERY close I'll let you guys do the math:
As a final note: US built Ford trucks from 48- (at least) 52 were NEVER refered to as "1/2 ton", "1 ton", etc, in ANY US Ford documentation. They were always classified and refered to by their GVW rating.
on
I think the key to converting an F-2 or F-3 to an F-1 has to do with the parts it comes with. Like Panelman says the only body parts that are the same are the cab, doors, hood, and grille. So if you find an old F-3 that has those good parts and needs everything else then it might be more feasible to convert it than one which has good fenders, bed, and running boards. My F-3 came with a good cab, hood, and doors but no bed or rear fenders. I had to replace the front and rear fenders, running boards, and the bed so it was actually less expensive for me to shorten the frame and buy F-1 parts than try to find good F-3 parts.
I think we need a sticky on this, entitled "If you want an F-1, Buy an F-1"
There is one advantage to buying an F-2; the crossmember for the big 4-sp will clear just about any modern tranny whereas the F-1 LD 3-sp crossmember doesn't work for much of anything modern. That is an advantage if you are going darkside, of course.
Another disadvantage is that you'll need to create a complete new e-brake system (assuming it has the drum on the driveshaft).
