1967 Ford Ranger
Old Sep 13, 2010 | 10:41 PM
corner27's Avatar
corner27
1967 Ford Ranger
I have a couple questions about a truck I found. The guy states it's a 1967 Ford Ranger. Would this be the same as the F100? He also says it has a 351w, but from my research, that engine was not available in the trucks in that year. Someone please correct me if I'm wrong.
What engine and tranny was available in this truck?
Thanks,
Corey
Old Sep 14, 2010 | 07:56 AM
Unimog005's Avatar
Unimog005
I think the Ranger can be an f-100 or an f-250.....mine is an F-250...and 4x4....
"Ranger" pretty much dealt with the badges and some of the grillwork....one thing about the 1967's though....they were a "one year only" truck...meaning many things body and interior wise happened only on that truck....
The original V8 offered was the 352....but many have been retrofitted with other options....mine has a 390.
Numberdummy will have to fill you in on which trannys were an option...mine was retrofitted with an np435/np205 package from a 77-era truck..
Old Sep 14, 2010 | 08:34 AM
67nukeford's Avatar
67nukeford
Veteran: Navy
I don't think the small block was offered until 69, and that was the 302. Someone must have swapped motors.
Old Sep 14, 2010 | 09:23 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Would this be the same as the F100? He also says it has a 351W, but from my research, that engine was not available in the trucks until 1981.
Seller is prolly clueless...has mistaken the 352 that was the only V8 available in 1967 with the 351W .. which was not available until 1981 in F150/350's & Bronco's.
The engine code is the 4th digit of the VIN.
1967 F100/350: A = 240 1V I-6 / B = 300 1V I-6 / Y = 352 2V.
FE engines (352/360/390and etc) have 5 valve cover bolt holes per side, 351W's (& 221/260/289/302's) have 6.
Available transmissions:
M/T: 3 speed manual, 3 speed with overdrive (F100 only), New Process 435 & Warner T-18 4 speeds.
A/T: C4 Cruise-O-Matic (240/300) / MX Cruise-O-Matic (352).
Rangers were available in 1965/66 as F100/250's only. F350 Rangers were available beginning in 1967.
Old Sep 14, 2010 | 09:25 AM
corner27's Avatar
corner27
The reason I asked is becuase I was interested in the drive train from it for my 48. I know the rear will work, but I am looking for a 351, so the engine from this truck won't work for me.
Old Sep 14, 2010 | 09:28 AM
NumberDummy
351W: 1969/86 misc Passenger Cars / 1975/96 Econolines / 1981/96 F150/350's.
1980/83 F100: The largest V8 available was the 302.
Old Sep 14, 2010 | 10:52 AM
jowilker's Avatar
jowilker
As unimog stated, there very well could be a 351W in there today. Lots of things can be swapped in 40 years. It just didn't come with a W in it.
May be worth further investigating.
John
67nukeford
Nebraska Chapter
48
Nov 2, 2014 07:56 PM
hombre292
33
Sep 28, 2014 04:36 AM
Jasonnoel
13
Aug 13, 2014 09:20 AM
Falconman#3
15
Apr 27, 2014 10:51 AM
oldfatandtired
Large Truck
Jul 23, 2011 12:15 PM
