I broke the spark plug in half !!! It left the ceramic in the
engine side Can this be drilled out or punched out with out removing the head ?? The hex is not on the plug !! I will need to use an easy out but
I am afraid of punching or drilling the ceramic .........
Any one had this problem before
If you get any debris in the combustion chamber, a thorough cleaning with a vacuum with a flexible hose that will fit into the sparkplug hole can take care of it(I've used one that was designed for cleaning computers and keyboards)
That is dicey, just one chip of ceramic left wedged between the wall and piston will create havoc.
If you still want to attempt the extraction, load the drill tip with heavy grease (collects debris), go slow and clean often.
Once you have the plug out, run a thread chaser (not a tap) through the hole, again, loaded with grease.
Personally I would be removing the head.... Good luck!
There are flexible scopes that will let you look inside the cylinder though the plug’s hole. A friend has one related to checking his valves as part of his airplane’s annual inspected. Good Luck! JOW
I had one of those broken sparkplug events this past weekend on a 3.0L V6 in a Ranger. The plug snapped off at the hex. An air nozzle blew the remaining porcelain tip out of the head. It can't fall in due to the shape and the electrode at the tip of the sparkplug. An Irwin/Hanson EX-5 was the perfect sized extractor. You first have to remove the small gasket that is located in the bore of the plug so that the easy-out will seat fully. A liberal application of "Blaster Penetrating Catalyst" is recommended. Adding some heat to the base of the plug and head helped. In order to get a good grasp on the easy-out extractor, a Craftsman 3/8" 12 point socket (short one) will fit perfectly. Be careful and be patient. I let the "Blaster" soak in for a few hours and gave it a second application before applying the heat. There is some risk in all this, with the payoff being about $10.00 worth of harware store parts vs. taking off the head. There was no drilling and no broken bits going in the engine. Take your time if get into one of these situations. LJB
