Bad Deal
Old Sep 13, 2010 | 06:42 PM
thekingofcows's Avatar
thekingofcows
Bad Deal
My dad has an 86 f150 4x4 with a 300. The thing has always run really good except, the other day I drove it into town to get some gas and on the way the engine completely quit, I figured maybe it was out of gas and I was going at a good clip so I just left it in gear so maybe it would start back up however, after about 10 seconds of coasting I heard an explosive pop, and I pulled the truck off the road. The muffler had completely blown out the welded seam. I say all this to say:
I think perhaps that something in the ignition circuit quit and the motor was getting no spark, and since combustion was not taken place in the engine, it took place in the muffler resulting in the muffler's catostrophic failure. SO MY QUESTION IS: What do ya'll think could be the culprit of this catastrophe?
Old Sep 13, 2010 | 07:22 PM
Diesel_Brad's Avatar
Diesel_Brad
THE DRIVER
Old Sep 13, 2010 | 07:48 PM
TheKirbyMan's Avatar
TheKirbyMan
And how exactly could it be the driver's fault?
Old Sep 13, 2010 | 08:36 PM
thekingofcows
Anyone else have any other ideas of what could of gone band? Ex. Ignition Module, coil, points etc
Old Sep 13, 2010 | 11:27 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
I think he might be insinuating the driver turned the key off, pumped the pedal a couple times and turned the key back on ...
Think dad might be mad!
But that is only my read on Brad's post and in no way means, that is what he meant!
Thekingofcows, Did it start again or is it still dead??
-Enjoy
fh : )_~
Old Sep 14, 2010 | 01:22 AM
Beaverman's Avatar
Beaverman
Timing chain let loose?
Old Sep 14, 2010 | 01:26 AM
TheKirbyMan
Oh ok, didn't think about it that way.
Old Sep 14, 2010 | 04:26 AM
Diesel_Brad
-Enjoy
fh : )_~
Exactly what i meant
Old Sep 14, 2010 | 07:58 AM
Eddiec1564's Avatar
Eddiec1564
Sounds like a TFI modual failing, better have a spare TFI and the special tool to R&R it when it fully craps out on you.
As a side note, I "lost" many mufflers due to afterburn. LOL So a stright pipe fixed that and made it more intresting for any tailgaters behind me....
Old Sep 14, 2010 | 10:12 AM
thekingofcows
300s dont have timing chains
it will not crank back up
what is the tfi module is the same thing as an igntiin module
appreciate it
Old Sep 14, 2010 | 10:55 AM
Grubbworm's Avatar
Grubbworm
Yes, the TFI (Thick Film Integration) Module is the Ignition Module. It is mounted on the side of the distributor. In this picture the module is located under the yellow oil dipstick handle and next to the oil filter.
Old Sep 14, 2010 | 01:57 PM
thekingofcows
appreciate it, I'll give that part a try.
Old Oct 25, 2010 | 02:52 PM
thekingofcows
Well over a month after my last post. And the truck has just been sitting there. I put a tfi module on it, however it did not help, I don't seem to be getting a spark, could it be a bad ignition coil?
Old Oct 27, 2010 | 09:59 PM
fltrxdave's Avatar
fltrxdave
Just asking....
Not trying to insult anyone here, but you've checked to make sure your getting power at the distributer right? Checked cap and rotor?
Old Oct 28, 2010 | 08:04 AM
Grubbworm's Avatar
Grubbworm
I have some troubleshooting help posted here;
Ford Truck Enthusiasts Forums - Grubbworm's Album: Troubleshooting help, for anyone that needs it.
Some of it may help you, check it out.
