New Fuel Tank
Old Feb 19, 2003 | 06:14 PM
1984_355w's Avatar
1984_355w
New Fuel Tank
I'm planning on changing my fuel tank this weekend in the '84. It has been leaking for a while so I orded one of those new Fangled Polypropolene Tanks with new mounting hardware. Is there anything special I need to do when changing them?? It is a side mount tank. Also, it says because the tank is plastic you have to ground the sending unit if it doesn't have a ground wired into it. Will I have to on mine or not??
Thanks Much
Old Feb 19, 2003 | 11:04 PM
steve83's Avatar
steve83
New Fuel Tank
I can't think of anything special, except use "Camper Mounting Tape" between the tank & support straps, and plan on running the ground. Also, use Anti-Seize lubricant when you reassemble it. If it didn't come with a new O-ring for the sending unit, get one.
Old Feb 20, 2003 | 02:43 PM
1984_355w's Avatar
1984_355w
New Fuel Tank
Thanks a bunch. I am going to use cut rubber strips out of old inner tubes and glue them to the straps and the frame with RTV. The new tank came with a new mounting ring and gasket so I'm good to go there. On the ground, Should I just run a wire from one of the sending unit retaining bolts to one of the tank straps. Would that work ok??
Thanks
Old Feb 20, 2003 | 10:22 PM
steve83's Avatar
steve83
New Fuel Tank
Run the ground to the frame, but there are no bolts on the sending unit - only a lock ring. You can see it in pics #44 & 45 here. Yours will be slightly smaller than that one, and it won't have wires like that, but the lock ring is similar.
Old Feb 21, 2003 | 06:53 PM
1984_355w's Avatar
1984_355w
New Fuel Tank
Sorry,
I meant on the new tank. Instead of the lock ring that screws in like the old one the one on my new plastic tank is held down by 8 screws. Another thing, the old sending unit was rusted REALLLLLY bad so I had to go to ford and get a new one. $116!! Ouch and I can't drive it to school for 4 days. Really missin the sound of my Flowmasters
batt312
Jun 16, 2024 11:52 PM
johnson2007
Feb 15, 2011 12:19 PM
aussiearcher
May 8, 2010 12:53 AM
4fords
Jul 28, 2009 01:40 PM
oldhalftons
Apr 12, 2005 10:33 PM
