what year ???
Old Feb 19, 2003 | 05:53 PM
badbbduck's Avatar
badbbduck
what year ???
hello all I'm starting on a new project...1970 or 71 f350 cutom flat bed dual... the radiator is missing... what years will fit... would a radiator from a 1985 f150 351 work... where can I go to find vin refrences to figure out what all is in this... thanks michael mcbride
Old Feb 19, 2003 | 07:09 PM
mk's Avatar
mk
what year ???
Welcome to the group! If you want to post the info from your door tag, we can help you figure it out.
mike
Old Feb 19, 2003 | 07:14 PM
gtex's Avatar
gtex
what year ???
I doubt the 85 radiator would fit without modification. I would go with one from a 67-72 F Series with an FE or 385 series "Big Block", 360, 390, 429 and 460 most common and should have enough radiator to keep things cool.
the 73-79 may also bolt up, but I can't confirm that.
Old Feb 19, 2003 | 07:33 PM
badbbduck's Avatar
badbbduck
what year ???
oops, should've posted these the first time
heres what I've found... f350 custom m66803, f37xkm66803, chassis - cab 135mf374238a27 , also 10000 ,151 , 4000 , 52
thanks in advance mike
Old Feb 21, 2003 | 07:35 PM
mk's Avatar
mk
what year ???
Here we go, from what I could figure out from memory and my info:
F37- 1 ton series
X- this is the engine code position; are you sure that isn't a 'Y'?
(360 engine)
K- Kansas City assembly
M66803- sequential unit number. Indicates assembly in early fall
(possibly Oct- date codes on your windows, seat back,
engine block etc will narrow it down) of 71 (72 model)
135- wheel base
M- paint code ( wimbledon white)
F374- chassis (I think)
28- cab style (I think)
A- transmission (4 spd New Process)
27- rear axle (Dana 70, 4.10:1)
10000- Gross vehicle weight in lbs
151- HP @
4000 rpm
52- DSO (sales district code) Des Moines
If I'm wrong on any of these, feel free anyone to give corrections...
mike
