Axle seal replacement
Old Sep 13, 2010 | 05:00 PM
79FordBlake's Avatar
79FordBlake
I made a post a couples days ago about replacing the wheel bearings on my 79 Bronco. Well today I replaced the front wheel bearings, wheel seals, spindle bearings and seals.
While taking everything apart on the passenger side the axle slid out some( I thought to myself that axle seal is gonna leak now). Got it all back together and parked it in its normal spot, slightly on a hill. Got out and looked down, gear oil was pouring out. Never leaked a drop before.
Its been a couple years since I have replaced axle seals on a Dana 44. What do I need to watch for? All I can think of is make sure I remember to lay out the shims and such in the order in which they go so back lash, preload and such will still be right. Then torque the caps and so on. Thanks.
Old Sep 13, 2010 | 06:43 PM
Friesian-Bronco's Avatar
Friesian-Bronco
The carrier bearings on a 44 are pressed on Over the shims... you can't loose them.
G.
Friesian-Bronco
G.
Old Sep 13, 2010 | 07:16 PM
mark a.'s Avatar
mark a.
I wouldn't worry about it just yet, wait a while and see if it stops. Quite a bit of oil may have leaked into the housing tube. One other thing, make sure the axles vent tube isn't plugged up.
CraigOutdoors's Avatar
CraigOutdoors
I need to do this on my D-44 front end. The drivers side leaks. Let me know how it goes and if you can take pictures and post 'em while you're doing it, that'd be great.
Old Sep 13, 2010 | 07:43 PM
79FordBlake
Will do but for now I guess I will wait it out a little while like Mark a said and see what happens.
79FordBlake
17
Mar 19, 2014 08:10 PM
Halfbad
Mar 21, 2008 09:44 AM
brown 4x4
Oct 3, 2003 05:06 PM
tom100
Aug 25, 2001 08:11 PM
Elvis Juario
Sep 18, 1999 04:24 PM
