Engine Warm-up cycle
Old Sep 13, 2010 | 01:46 PM
CABGx3's Avatar
CABGx3
Hi All....
1989 E150 Club Wagon, 5.0, Auto, 61,000miles. Each time I go out to start up, the engine will not idle unless I feather the accelerator. After a couple of minutes it seems to "warm-up", and idle fine for the rest of the ride. I would understand this if I were up North in the winter, but this is Florida, 80 degrees......anybody know whut's up?
Vaya con Dios,
Chuck, CABGx3
Old Sep 13, 2010 | 11:15 PM
econoshorty's Avatar
econoshorty
Is it fuel injected?
Old Sep 14, 2010 | 04:11 AM
CABGx3's Avatar
CABGx3
Yes, it is Fuel Injected.........sorry, forgot to mention.
Vaya con Dios,
Chuck, CABGx3
Old Sep 14, 2010 | 11:05 PM
econoshorty
Have you tried disconnecting the battery overnight and let the ecu reset itself ? It's a run problem so there should be a code for the problem. I found this site it tells how to read codes on your van, pretty cool. Code Reader..... - Ford Bronco Zone Early Bronco Classic FullSize Broncos
Old Sep 16, 2010 | 04:16 PM
CABGx3's Avatar
CABGx3
Thanks, I'll check it out.........I just thought someone may have been able to identify the symptoms as having them before.
Vaya con Dios,
Chuck, CABGx3
Old Sep 16, 2010 | 04:53 PM
debra's Avatar
debra
has the fuel filter been changed at all recently?
Old Sep 16, 2010 | 04:57 PM
CABGx3's Avatar
CABGx3
Yes, the Fuel Filter was changed about a month ago......as was the Rear Tank, and both in-tank fuel pumps, and the Injectors were cleaned.......for reasons not related to this problem. The engine starts easy, and runs fine......it just has to have that little couple of minutes warm-up before it will idle.
Vaya con Dios,
Chuck, CABGx3
Old Sep 16, 2010 | 05:47 PM
debra's Avatar
debra
gotcha. that is a bit strange.
Old Sep 17, 2010 | 02:34 AM
econoshorty
According to the 1989 Econoline " Electrical & vacuum trouble shooting manual " (I found it on ebay ) there is a " idle speed control " unit in there somewhere maybe they have one at the parts store so you could see what it looks like. It's connected to the ECA if that helps.
Old Sep 17, 2010 | 08:06 AM
CABGx3's Avatar
CABGx3
LOL.........good point Shorty, I actually just bought one of those EVTM manuals myself off of ebay and "threw it in the pile".......guess I'll have to dig it out and start troubleshooting............I'll keep you posted as to what I find out.
Vaya con Dios,
Chuck, VABGx3
myforest1
1983 - 2012 Ranger & B-Series
13
Sep 27, 2021 09:51 PM
52 USCG Panel
22
Mar 31, 2016 03:50 PM
CABGx3
Nov 25, 2015 10:50 AM
Akmillman
Aug 5, 2013 05:53 AM
CABGx3
15
Jul 23, 2010 08:58 AM
