Rail Road dust in paint!!!!!!
Rail dust on 2012 f150 Larait
Hi couple question that I now you guys could answer for me I have a 2012 f150 Larait white truck I purchased about a month ago and at the time I was to excited and never noticed orange rusty looking dots on my truck called rail dust of course washing it don't remove it but quest question if I don't bother removing them will them dots eventually get worse and turn in the becoming rust spots or no I never thought about sitting there and removing ever single small rust dot rail dust but if u guys say that it will get worse leaving it then I will remove it I was just wondering is it a big deal or not
Since you have a 2012 - if it hasn't turned into a rusting hole by now you should be OK. The rail dust bonds to the clear coat, so as long as the base coat and the coating of the steel panels are intact it shouldn't be any more than a discoloration.
It is a tough question to answer, especially without pictures though.
If you bought it from a dealer, it is possible that there detail shop could get it out for you.
I've owned two Ram Heavy Duties, both white, both transported by rail, and both victims of rail dust. The problem most times is it's not gonna show up immediately, depending on where you live and the humidity in the air, because those metal particles need moisture to oxidize/rust and show themselves. In my cases it reared it's ugly head about 2-3 months after taking delivery. It was never an issue getting it out, other than the fact that there is a lot of acreage to cover on a full sized truck and in both cases it took me a day with a clay bar to get out and get a good layer of polish applied.
My question is what if I don't remove it will it cause future damage to paint and the metal and cause surface rust
You learn something new everyday! I've had this experience for years, but never new what to call them. A clay bar rub down will take care of most of them. I use by buffing wheel, experience with pressure and power on the buffer with some Mother's cleaner paste to get them off the really stubborn ones off. It takes time and it's not fun. I usually think I'm going to burn the paint off, but I haven't yet. I usually have to do it the Spring. After I get them all removed, a good patiently applied wax fully cured and removed makes it all better.
I have always been a believer that the deicers used in the rust belt are the culprits of this condition or at a minimum a catalyst. I think the chemicals get into imperfections in the paint and start working their mischief. Maybe it is rail dust. I don't know. I've had these on all trucks, but the silver and white ones show the worst. I've never not removed them, so I can't tell you what would happen. I figured leaving them was not an option for me as I hate cancer (rust) period. Take care of it early and it's elbow grease. Take care of it later and it's serious time in the shop. I don't have access to a booth so avoiding the booth is a priority for me
I honestly don't know. I have never been able to look at my truck too long with the spots on it. I'm assuming nothing would happen if you left it like that. Most people aren't going to go through the hassle of removing the crap, like some of us nuts do around here.. lol
Aside from "rail dust" these are normal contaminants kicked up from the roadways, paved or dirt. No vehicle is immune from this, and white generally is the easiest to see.
Like others have said, wash the truck first. Then get a bottle of detail spray or soapy water to use as lubricant for the clay bar and have a blast. After claying it is a good idea to wax.
#28
#29
Ok I'm a detail and painting professional. I paint and detail cars for a living. My question is how do you know it's rail road dust? Alot of times markings on vehicles are from insects and sometimes look like rust dots. My white 250 has them from time to time as well, just clay it with a quick detailer or soap and water and it will be fine
#30
