I bought the plow with the truck its worked fine when i drove home and took it off. It didnt have any di elteric greese on the connections. so i waited about a month and then put some on the connections... 2 days ago i put the plow back on fo ****s and giggles it wont turn right at all it would move up down and left. but wouldnt return center or go right.. When i pressed the right button the little light on my controller came on with the (im gussing a connection issue) Lightning bolt on it
I cleaned all the connections with some grease still on them..... When i push right on the pad i dont get the bolt of lighting anymore but it still wont turn right???/..... hydrolic issue??
