Sponsored by: Auxito
Engine barely running
Old Sep 12, 2010 | 09:51 PM
itfitz98's Avatar
itfitz98
2001 f150 4x4, 198k
So, Friday my truck started to loose oil pressure, it went right down to ZERO, but when I would shut the truck off and restart, it would come back up for a few minutes and then back to zero. So my wife googled it and determined it was a clogged up oil filter, so I had the oil changed and that seemed to fix that problem.
later on that day, I was about half way home and she just started to sputter and stutter and wouldnt hold an idle, so I had it towed home. Again I had the wife google it and she found that it was probably a faulty AIC valve, replaced that and to no avail, problem not solved, limped it to advanced auto parts and tried a MAF as well and that didnt do anything.
ran the computer on it and it pulled 4 codes total.
1. Idle air control ckt
2. lean bank 1
3. lean bank 2
4. miss fire on cyl 4. (this happened before on cyl 5 and was nothing like what its ddoing now)
also for the past couple weeks, there has been like a rattle/pinging sound coming from the front of the motor, more towards the passenger side, but from where it sounded like it was coming from it was not inside the motor like if it was lifters or rockers.
Oil is also clean with no water in it.
It is sitting at the tire store down the road to have advanced diags done on it tomorrow.
Any thoughts?
Old Sep 12, 2010 | 09:52 PM
itfitz98's Avatar
itfitz98
by the way, 4.6 motor.
Old Sep 12, 2010 | 10:07 PM
itfitz98's Avatar
itfitz98
one more thing, no power brakes either.
Old Sep 13, 2010 | 01:01 PM
Bluegrass 7's Avatar
Bluegrass 7
Respectfully;
What are the codes.
We do not go by what somene else says because most of the time they are miss interpeted by those who don't know what they mean.
Codes do not tell you what parts to replace.
Btw, an oil filter that is plugged shows gross neglect of the engine.
A spec filter would go into bypass and not starve the engine of oil.
A pressure issue may just be the oil switch on the filter adapter.
You need to look at all this from an informed position. If not, you will spend needless money, time and hassle.
Sounds like the engine has at least two faults.
You need to keep from being confused by more than one issue at the same time..
Good luck.
Old Sep 13, 2010 | 01:36 PM
itfitz98's Avatar
itfitz98
Well, at this stage of the game, the truck has zero comepression on the pass side, the thought it that it has jumped time.
Whatcha think?
Old Sep 13, 2010 | 01:48 PM
Bluegrass 7
Might as well bank on replacing the motor.
How did you check the compression?
One chain could be broken or jumped pf the cam gear.
The tensioners are oil pressure controlled so you would have to at least take the front cover off to see what you have and the valve cover for that bank to see if the cam is even moving.
The oil pump is also at the front of the crank behind this cover. It may be damaged.
Old Sep 14, 2010 | 12:29 PM
itfitz98's Avatar
itfitz98
well, the engine was neglected, I'll take the hit for that one, the oil had about 18k on it.
my next move is to find another motor for it and do a swap in the near future, in the mean time I found a 95 ford conversion van. clean inside and out, excellent shape for about $3500. so thats what I'll be pimpin for the next few months.
Old Oct 5, 2010 | 08:56 PM
itfitz98's Avatar
itfitz98
Question
This week I'm going to start digging into the motor and see what I can find out. My thought was that maybe, just maybe when she finally locked up was that the timing chain had snapped and is jammed up around the gear at the crank. Also I was told that because of the cam sensors that if it aint turning it will shut the motor down.
My plan is to start by tearing into the timing chain cover and see what I can find there and then move onto removing the head to see how tore up it is and what else may have been damaged. I have had some tell me that it is an interference motor and others that its is not. It is a 01 f150 4x4 offroad with a 4.6 romeo. a definitive answer would be great. Also if it is an interference motor then at the very least the head is tore all to hell on that side, correct? and possibly the pistons may be full of holes from the valves too.
thanks in advance for the help. I already have another motor lined up so however it works out, it works out, but I like to tinker anyway.
Old Oct 5, 2010 | 11:21 PM
93 mix 'n match's Avatar
93 mix 'n match
why....how does ANYONE let the oil go for 18k miles? im confused here.
YOU are about to tear into a motor, and ultimately replace a motor, but you needed your wife to google a bad oil pump? how do you know how to swap a motor, but not how to change oil? to what extent is your mechanical knowledge?
guess that went out the window too didnt it.
i dont know if its just that its late or whatever, but this whole thread.....dumbfounds me.
Old Oct 6, 2010 | 11:45 PM
eallanboggs's Avatar
eallanboggs
Next time I'm looking for a good woman I'm going to make sure she will google my engine problems for me. If she'll clean the fish I catch I'll marry her.
WnterHwk
1997 - 2003 F150
Jun 12, 2012 02:19 PM
9902ford
1997 - 2003 F150
Jan 13, 2010 01:56 PM
mds79
Oct 6, 2008 12:02 AM
4601ton
3.0L V6
Aug 30, 2006 07:00 AM
911bear
Feb 23, 2006 11:11 AM
