Blow-by causing IAC problems?
Old Sep 12, 2010 | 04:29 PM
kentuckyredneck's Avatar
kentuckyredneck
My truck ('92 F-150 302EFI) periodically goes into an extremely high idle. I think the IAC needs cleaned. I don't have any carb cleaner, but i took the IAC and the other part it attaches to off to look at them. When I took the hoses from the airbox off, they had oil dripping out of them. The inside of the IAC and the other part had oil in/on them and the back piece had what looked like oil crud in it. Could blow-by cause this? If not, then what is it?
Thanks in advance.
Old Sep 12, 2010 | 06:14 PM
rla2005's Avatar
rla2005
It is not common for this vintage truck to have some oil deposits in the intake. As the engine gets some miles on it the problem can be amplified. Check/replace your PCV valve and the breather element in the airbox.
Your case does appear to be more than what I would expect. Clean the intake tract out, start with the new PCV and filter. Keep an eye on it. If the build up comes back quickly, it may be time for a leak down test.
Old Sep 12, 2010 | 08:37 PM
kentuckyredneck
Dumb question, what and where is the PCV? I can't find the filter for the tube, can i modify one of those oldfashioned valve cover breather filters and put on it?
Old Sep 12, 2010 | 09:05 PM
rla2005's Avatar
rla2005
The PCV (Positive Crankcase Ventilation) is located on the passenger side valve cover underneath the upper intake. Not a very good design IMHO. The fresh air intake filter is located underneath the engine air filter. There should be a tube running from the driver's side oil fill tube to the air filter box.
A few have tried using the breather filter you mentioned. It should work, but if you have emissions testing they may not be too keen on that setup.
Old Sep 12, 2010 | 09:16 PM
kentuckyredneck
so, I need to remove the upper intake? Great!lol. We don't even have the crap where they plug the truck in for emissions here. Most people run straights or glasspacks and my smog system's comin off.
Old Sep 12, 2010 | 10:54 PM
old_lynrd's Avatar
old_lynrd
no u can access w/o pulling the intake..its on the back pass side of valve cover and has a tube going to the intake mani
Old Sep 13, 2010 | 07:33 AM
rla2005's Avatar
rla2005
It is darn near impossible on my 5.8L engine to pull the PCV without removing the upper intake, the 5.0L is a little easier like the previous reply indicates.
Old Sep 13, 2010 | 07:57 PM
kentuckyredneck
Alright thanks.
