Intermittent Engine Stutter
Old Sep 13, 2010 | 09:18 PM
savage250's Avatar
savage250
on question I still have, can someone explain to me how the o-rings being bad can cause the problems I am having?
And are they getting worse by me still driving?
Old Sep 13, 2010 | 09:21 PM
fordpride's Avatar
fordpride
cause the injectors are not getting the oil pressure they need some of the oil could just be blowing pass the injector orings
Old Sep 13, 2010 | 09:22 PM
fordpride's Avatar
fordpride
i drove mine for awhile with bad orings
Old Sep 13, 2010 | 09:38 PM
savage250's Avatar
savage250
oh, I didn't understand because I thought the oil was completely internal in the injector, I didn't realize that the o-rings were sealing oil inside the injector as well. I just assumed the injector body kept the oil internal, and the o-rings sealed the injector into the head.
So the nozzle of the injector fires directly into the cylinder, correct? Not into a plenum or valve?
Old Sep 13, 2010 | 09:45 PM
fordpride's Avatar
fordpride
the oil come into the injector from the head the oil rails are built into the heads
Old Sep 13, 2010 | 09:46 PM
fordpride's Avatar
fordpride
yes sir thats correct
Old Sep 14, 2010 | 10:20 AM
jchosler's Avatar
jchosler
I get a little stutter. I put in a TE modded HPOP which got rid of it but it came back a little bit ago. My injectors are still "new" from Rosewood so I don't think it's the o-rings. I feel like a lot of these problems with the OBS's are related to fuel which I plan on upgrading soon. Goin electric, gonna piece my own kit together, but I think that'll probably take care of that issue
Old Sep 14, 2010 | 10:45 AM
savage250's Avatar
savage250
And when it's rolling down the highway, it all seems fine. With my SCT plugged in for my "gauge" I can get to 15psi boost, so I wouldn't think I have any problems there, but who knows for sure....I will work through all the leaks or whatever is making my mess in the valley first, and do a buzz/cct check.
I seem to be able to create the stutter most often if I let out the clutch in first, let it creep along at an idle, when I push the clutch in, it stutters for a second or 2, still about 500rpm, just feels rough, and then just rights itself. When it's idling along under load, no stutter.
And since I cleared the 236 code, it has not returned.
Is there any diagnostic way of checking injector o-rings without taking them out?
Old Sep 14, 2010 | 10:58 AM
jchosler's Avatar
jchosler
I'm afraid the only way to check is to pull them. It's a lot of labor but pretty straight forward. I hated pulling mine because prying them out proved to be difficult, I actually cracked one of the solenoids mounted on top of the injector... Very frustrating
carguy3j
92
Jun 9, 2021 06:16 AM
dborns
Escape & Escape Hybrid
Jul 7, 2019 12:04 AM
ScottInTexas
1997 - 2003 F150
Feb 4, 2017 05:50 PM
Chado101
Jul 8, 2015 01:50 AM
jayzeller79
Sep 7, 2013 04:42 PM
