Underneath Bed Help
Old Sep 11, 2010 | 04:07 PM
dfwbullitt's Avatar
dfwbullitt
Underneath Bed Help
I want to strip all this crap, rust, dirt etc. off and use something like POR and an undercoating on it. My question is what is the best way to get all the crap off or neutralized that I cant get to with a wire wheel, or sandpaper?
What's the best way to restore the underside of the bed in general? Step by step instructions would be great......
Old Sep 11, 2010 | 04:42 PM
blackmajikf100's Avatar
blackmajikf100
well you have the options of using rust remover, automotive acid, or a sand blaster, or go really cheap and use rust penitrating primer
Old Sep 11, 2010 | 05:02 PM
dfwbullitt's Avatar
dfwbullitt
if i use a rust preventative primer, and then spray an undercoating over that, how much surface rust do i have to get off? I really wish i had a blaster, but i don't so i'm trying to figure out ways to do the best job on this myself without spending a ton of money.
Old Sep 11, 2010 | 06:25 PM
Phil105's Avatar
Phil105
I had little to no rust under the bed but I did have 38 years worth of Georgia red clay under there. Guess it "protected" the underbed!!
I just used a 3000 psi pressure washer, sanded what I could and then sprayed undercoat.
May not be the best solution, but I figure if it hasn't rusted out in all this time, I'm not gonna worry about another 38 years!!
Good luck with yours.
Old Sep 11, 2010 | 06:51 PM
sandmanf250's Avatar
sandmanf250
underbed
if you want to do it right, take it off,pressure wash it ,undercoat it and reinstall.not hard to do.iff your in a nonsalt area,just clean it good and apply some new paint.
Old Sep 11, 2010 | 10:33 PM
JRM1972's Avatar
JRM1972
I pressure washed mine, wire wheel brushed everything I could get to, shot a coat of primer, and used 3m shutz undercoating.
Old Sep 12, 2010 | 02:35 PM
blackmajikf100
i would suggest seeing if a friend has an air compressor and you can buy a sandblasting gun for like 100 bucks or so just to get the corners me personally im paying 500 bucks to get my truck media blasted and im powdercoating the frame and rinolining the bed bottom and cab bottom as well as some other areas . the rust PREVENATIVE primer does not remove rust it just covers the area and will help to postpone rust for a decade or so
