1994 clutch issue
Old Sep 11, 2010 | 11:56 AM
konaphil's Avatar
konaphil
1994 clutch issue
This is a 5-speed truck with a zf trans. It seems to work fine when cool. However after normal driving ( not hard with a lot of clutching), the pedal sticks to the floor, and must be forced up- then it engages very high. Also, sometimess the trans doesn't engage at all with the clutch all the way up. It did this recently, and I was lucky to get the truck home. The next day, I moved the truck a short distance, and it worked fine. Help guys- what is this problem?
Old Sep 11, 2010 | 01:27 PM
octaneforce's Avatar
octaneforce
clutch cable? or maybe take a look under the dash and see if everything seems to be moving back and forth properly. just a shot in the dark.
