help! horn and seed control
The one thing in common with these two functions is something called the clock-spring. It's a spiral-wound, flat ribbon cable that's part of the steering column assembly, and is replaceable.
However, this could be something as simple as it being unplugged inside the steering column.
You're going to have to dig down into the column to find out. Just beware, there's an air bag there that needs to be disarmed first.
Pop
Pop
this is on my list too. can't pass a Federal safety inspection without a working horn. I kinda don't care if the horn works. In this vehicle, if something gets in the way I know what will win. And if it's something bigger than this truck, it's probably too slow to move outta the way when I hit the horn.
anyway, all kidding aside about saving some poor pedestrian, I know it's a part inside the column. but haven't been fired up to figure out the airbag angle. never had a vehicle with an airbag before.
Don't forget to check fuses.
If you have to change the clock spring, it's not too hard. Just remember to handle the air bag so that if it decides to go boom, it's not in your face.
https://www.ford-trucks.com/forums/6...l-removal.html
Mikey Cash
08-02-2013 08:40 PM
Freybaby
11-15-2006 01:47 PM
Encounter
09-01-2003 03:32 PM
