2007 found keyless entry code for free
Old Sep 11, 2010 | 10:13 AM
vipersinu2's Avatar
vipersinu2
2007, mecury mountaineer, ford explorer, door keyless entry code is located on the fuse panel under driver side dashboard, it is called SJB smart junction box, it is a 5 digit code printed about 1 inch from the bottom of the fuse block, you can not see the number off hand because it faces the metal frame of the car. stick your cell phone between the car and the fuse panel and start taking pictures! here is a picture.
it is located on the smart junction box (sjb)
I used my camera like this to get the code printed on the sticker. (Note this is just an example; this explorer did not have a keypad option so there is no 5 digit code on this sticker but it would be there if it did)
here is another picture on an 07, I think after 07 they went to the sticker method.
this picture was taken again near the e-brake pedal. I blured out the rest of the code.
Zoomed in on photo
as you can see there is the code in less than 5 minutes, and no tools required.
also check this link,
http://explorerforum.com/forums/showthread.php?t=295870
or this
https://www.ford-trucks.com/forums/1...ml#post9958750
Old Sep 11, 2010 | 07:53 PM
V8Ranger302's Avatar
V8Ranger302
My old 88 Lincoln Mark VII, it was on the trunk lid hinge
Old Sep 29, 2017 | 04:40 PM
Scott Burdette's Avatar
Scott Burdette
Thank you, for this information
Old Oct 5, 2017 | 10:57 AM
explorerdriver's Avatar
explorerdriver
You can also download an app called Forscan, it should read this code and tons of other useful parameters.
Old Oct 14, 2017 | 09:51 PM
WilliesSD250's Avatar
WilliesSD250
I just bought a REALLY clean 06 Mercury Mountaineer w/ key less entry. Unfortuantly, I don't have the 5 digit code for it. Where can I find mine. Also, where can I get additional key fobs. I only got 2 keys and one transmitter with my purchase. Thanks!
mikeo0o0o0
1221
Mar 24, 2025 09:27 PM
a truck named effy
Air Intakes, Air Filters & Ram Air
35
Feb 14, 2021 07:27 PM
ironman540
123
Aug 20, 2017 05:54 AM
armyaviation
Jul 3, 2017 12:29 PM
meborder
2009 - 2014 F150
37
Jun 19, 2017 11:54 AM
