Fuel system?
Old Sep 11, 2010 | 01:25 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Fuel system?
Well, my new-to-me '88 7.3L needs plenty of attention to the fuel system. The side tank is leaking pretty bad, and the injectors literally have a steady stream of fuel leaking out while running.
Now, are all the tanks interchangeable (as in diesel vs. gas)? So if I get a new gas/fuel tank for any F250/350 it should work, right? Fuel pump mount and sending unit mount the same for gas & diesel?
Secondly, what is everyone using for injector O-ring kits? Should I just replace all the injectors?
Any other areas I should inspect? Problem areas?
I'm told the engine only has 50k on it...
Old Sep 11, 2010 | 04:06 AM
Lazy K's Avatar
Lazy K
https://www.ford-trucks.com/forums/9...intrusion.html Read here.
Old Sep 11, 2010 | 01:03 PM
LCAM-01XA's Avatar
LCAM-01XA
On the tanks, just order those for diesel trucks - they are physically the same as the gasser ones, but I'm not sure if the clocking is the same for the fuel pickup assemblies - and they should be the same price anyways, so might as well do it right the first time.
Injector return line kits - those can be had from about anywhere, the problem is they come with rubber o-rings which are more likely to spring a leak if the injector cap is disturbed somehow later on. There are upgrade o-rings available, they're made of viton and they hold up to diesel fuel much better - you can get those from an industrial supplier like McMaster-Carr. Or, one of the members on here sells return line kits with the viton o-rings included, and his pricing is very reasonable, so you can go this way as well.
Old Sep 11, 2010 | 06:54 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Thanks for the information. The link Lazy posted was exactly what I was looking for.
Parts are ordered... Viton O-rings and the installation kit (AdvanceAuto Parts wanted $87 for the kit, when Pensacola had the same kit for $19 )
Direwolf23
Dec 25, 2015 06:01 PM
AtlM5
Dec 13, 2015 07:46 PM
johnvirgil
30
Dec 7, 2015 04:52 PM
trailerbred
Jan 4, 2009 01:48 PM
