ATS housing
Old Sep 10, 2010 | 07:47 PM
crazer42's Avatar
crazer42
ATS housing
so i was dead set on just doing the ww, but now my buddy is trying to talk me into doing a ats housing i have looked into them but its quite a bit more thank the WW does anyone else make a comporable housing that does the same thing for cheaper?? and what about combinig the ww and the ats housing
Old Sep 10, 2010 | 07:54 PM
big poppa's Avatar
big poppa
If you can spring the cash the ATS housing is the prefered mod of the two, pretty sure it eliminates surge all together. I had the WW and it helped me plus a bit of whistle mashing on it. An ATS housing plus a WW equals a wicked whistling effect, heard it first hand and its loud, not for the faint at heart unless you like a loud whistle.
Old Sep 10, 2010 | 08:04 PM
crazer42's Avatar
crazer42
i dont mind me some turbo whine but how is it like whistle all of the time or just when you are on it hard? and will the ats with the stock wheel whistle more than our stock setup?
Old Sep 10, 2010 | 08:15 PM
big poppa's Avatar
big poppa
From the truck I heard it from it was all the time whistling, all thru the powerband. Guys here that have or had that setup will respond to their experiences. Yes, the WW with your stock turbo will whistle more but just on exceleration, getting on it of sorts. Thats my observations when I had my stock turbo with WW.
Old Sep 10, 2010 | 08:20 PM
Izzy351's Avatar
Izzy351
I've had a stocker with WW and ATS with stock wheel on my van turbo. The ATS does allow more whistle than stock, and the stock wheel moves more air than the WW, so combining the two isn't really beneficial, other than making a lot of noise. I really like how my truck sounds right now and I'm getting over 35psi out of my van turbo with no surge......
Old Sep 10, 2010 | 08:24 PM
crazer42's Avatar
crazer42
ok so would a ats ans a ww make me loose some power or just not gain any
Old Sep 10, 2010 | 08:28 PM
Izzy351's Avatar
Izzy351
It's not that simple. I need ALL the air I can get due to the hybrid injectors I'm running. With stock injectors, I don't think you'll over fuel the turbo with the ATS even with a WW, but you will be making lots of noise....
Old Sep 10, 2010 | 08:42 PM
Sheldon Plankton's Avatar
Sheldon Plankton
I recall a post by bdrummond where he was saying that he had BOTH the WW and the ATS housing and he had to go back to the stock wheel. He said it sounded like a dentist's drill running in the cab all the time.
Old Sep 11, 2010 | 07:06 AM
spdmpo's Avatar
spdmpo
The ww isn't as efficient as the stock wheel. Doing both wouldn't be beneficial i would think. The reason for doing the ww is its just a cheaper alternative to the ats housing, but it may not fix the problem all the way and isn't as efficient. If you can swing the housing just do that. But then later you'll probable want a 1.0 exhaust housing andthen you're half way to a38r.
Old Sep 11, 2010 | 02:13 PM
sledhead999's Avatar
sledhead999
I you can spring for the ATS housing do it. I had bad turbo surge when hooked up to my trailer, absolutely NONE now, plus its easier than installing a wheel.
Old Sep 11, 2010 | 03:55 PM
USAF CCM's Avatar
USAF CCM
YEP! I agree completely with spdmpo's statement. I went with the ATS housing and kept my stock compressor wheel. My air filter is the AIS so the noise isn't a factor for me.....I've already lost enough of my hearing due to flying in the back of a KC-135 for 20+ years. I want to drive in quiet comfort (as much as is possible so I can hear my stereo). I love the power (w/DP tunes) at both the high & low ends.
Wayne64SS
Nov 5, 2010 08:39 AM
Full Throttle
15
Apr 20, 2009 10:20 PM
makomaker
35
Apr 29, 2008 07:57 AM
02GrayPowerStroke
Jan 15, 2008 12:37 AM
tholt34
20
Oct 25, 2007 09:44 PM
