No drive or OD
Old Sep 10, 2010 | 07:42 PM
10 sec brutus's Avatar
10 sec brutus
No drive or OD
Hi all , removed speed sensor in diff (94 F350 idi turbo) , since putting it back together i get the ABS light on & the tranny will pull away i 1st, 2nd but just rev in drive , any thoughts.
Thanks.
Old Sep 10, 2010 | 10:39 PM
George D.'s Avatar
George D.
um what this should be impossible with all electronis on the trans failed you should have in OD 2nd and 3rd. Are you saying that if you put it in OD and try to take off it doesent move but moves if first and second are manualy selected? Be very clear when describing whats going on the messing with the speed sensor and the ABS light sound like an electrical problem but the trans symptoms sound like a valve body problem. Does the OD light flashing? Is the speedo working?
Old Sep 11, 2010 | 10:23 AM
10 sec brutus
Seems the speed sensor has fallen appart in the diff , can anyone help me with a part number so as i can get it cross refferenced in the UK?
Thanks , need this truck back on the road.
Old Sep 11, 2010 | 12:33 PM
Lazy K's Avatar
Lazy K
Go to rockauto.com and enter your truck details, then click on "electrical" and then on "VSS". Should be around $20.00 and they will ship overseas.
FordRun
Nov 27, 2012 04:49 PM
welder309
2009 - 2014 F150
Oct 25, 2010 06:36 PM
NV250
Sep 17, 2008 01:55 PM
MER
Mar 8, 2008 09:28 PM
Rusty1
43
Dec 31, 2003 05:46 PM
