Sponsored by: Real Truck
Overdrive light
Old Sep 10, 2010 | 06:48 PM
Rider15's Avatar
Rider15
Overdrive light
I have a 2004 F-250 SD Triton V-10. There is a light on the Automatic shift lever for OVERDRIVE.
The other night I was trav eling on the interstate at 77.5 mph in cruise control. The OVERDRIVE light started flashing. Then it stopped for a while, then it started again. Nothing seemed to be wrong with the truck at the time, all was running fine.
Anybody know why my OVERDRIVE light was flashing. Owners manual was no help.
Thank you
Old Sep 10, 2010 | 08:22 PM
2002 F350V10's Avatar
2002 F350V10
start with the cheap fix. $25-$35 or so. the abs sensor on the middle of the rear axle right above the driveshaft. That little sensor creats the pulses which control the abs, speedo, trans shift, and cruise. if it is not reading correctly, it will throw codes and cause the od light to flash.
Old Sep 10, 2010 | 09:26 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
There are about 50 things you can replace that MIGHT fix the problem. You'll spend a lot of money without fixing anything.
The right way to fix this is get the codes read. Auto parts stores that read codes free can't read the codes that flash the OD light.
