6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
A Little Steering Problem
Old Sep 10, 2010 | 08:41 AM
pog23's Avatar
pog23
I have noticed that when I am driving on a straight road the steering pulls to the right. I am always having to hold the wheel to left a bit to keep it perfectly going straight on the road, that isn't my concern I think that will be fixed with a wheel alignment.
But now what I noticed is when im going at around 60-65mph and there is a bend on the highway going left, there is a humming sound produced from the front driver side tire. It's only noticeable if the music is turned down at the bend or if you really pay close attention.
Should I get this looked at right away? Or wait till it gets more noticeable?
I am hoping its not the Hub. The tires on the truck are 35" Toyo Open Countries.
Thanks
Old Sep 10, 2010 | 09:16 AM
senix's Avatar
senix
could be a wheel bearing issue. Since you are running oversized tires the hubs won't last as long as stock. How many miles?
Best thing to do is probably raise the tire up in the air and see if there is play.
Old Sep 10, 2010 | 09:25 AM
pog23's Avatar
pog23
I just bought the truck few weeks ago, but the previous owner had put them on about 6k ago. Not sure what was on it prior to. It's going in for a tire rotation soon so maybe I should just mention it to the mechanic? they will probably charge for every little thing though. Thanks Senix always quick to reply!
Old Sep 10, 2010 | 09:40 AM
senix's Avatar
senix
Well that is just my thoughts maybe it is just the noise the tires make.
I suppose since you are going in for the rotation that will be a good test to see if the noise disappears or changes.
Old Sep 10, 2010 | 10:35 AM
pog23's Avatar
pog23
Exactly my thought. Maybe the rotation will change something. Hopefully it goes away, don't want to spend money on repairs rather it go to moding it!
Old Sep 10, 2010 | 10:46 AM
R-T0r21on's Avatar
R-T0r21on
Thanks
Toyo Open Country A/T, or M/T? Could just be a tire issue (radial pull). Obviously the M/T's will be noisier than the A/T's. I have the LT285/75R 18E A/T's myself. No issues from them on my truck.
Old Sep 10, 2010 | 11:04 AM
pog23's Avatar
pog23
I have the M/Ts. The noise is not what concerns me. Its the humming sound when turning the wheel slightly to the left at highway speeds. Normal city driving can't notice a thing just on highway when going around a left bend, nothing when going aorund a right bend.
Old Sep 10, 2010 | 12:34 PM
BASSHUNTER's Avatar
BASSHUNTER
Climb under the RH side of the truck and check to see if the Exhaust Down Pipe is touching the frame rail where the pipe has a factory flat spot to clear the frame.Mine did the same thing after i had cab off for HG's and the pipe was touching the frame and we had to readjust and vibration went away.
Old Sep 10, 2010 | 04:06 PM
pog23's Avatar
pog23
Thanks BassHunter, I dont get a vibrating feel though or sound, its just humming sound. I will for sure check that out though when I get a minute to crawl under it.
Old Sep 11, 2010 | 10:33 PM
bnmccoy's Avatar
bnmccoy
I had a humming noise as you describe on a car that I bought used; it didn't start until about two months after I bought the car. The right tire was getting worn on edge and after looking everything over the tie rod end was loose and had out of wack toe-in. Previous owner had the car aligned about six months before I purchased it. She also had the right tire blow out shortly before I bought the car. So the tire shop she bought new front tires from did not even inspect the suspension and they too missed the fact that the tie rod jam nut was loose.
I bought four new tires and alignment; and figured that was the end of it. The noise was still there; I ended up replacing the right bearing on the front wheel drive car. I figure the excess toe-out stressed it too much; and the damage was done...... BTW, I could find nothing wrong with that bearing assembly when rotating it by hand; but my loud hum or drone sound went away as soon as I replaced it.
So the point is; if not your tires; and even if your alignment needs corrected; may still be bearing assembly.
Good luck,
Bob
Old Sep 13, 2010 | 08:45 AM
pog23's Avatar
pog23
Thanks for the info Bob.
andydunks
Jun 19, 2014 09:57 PM
greennwhite 77
Feb 10, 2010 09:26 AM
xjcamaro89
2004 - 2008 F150
20
Jul 12, 2009 06:20 PM
bertcakes
27
May 2, 2004 07:39 PM
