trany swap
Old Sep 9, 2010 | 08:13 PM
jg96powerstroker's Avatar
jg96powerstroker
trany swap
hey there wanna see what you all no about swaping an auto trans out for a manual trans, its on a 93 7.3 f350 4x4, i have a doner truck with the 5 speed and the works. thanks 4 you help
Old Sep 9, 2010 | 08:53 PM
farmert's Avatar
farmert
If the donor truck had a 7.3 it is pretty straight forward. If it is a gasser it is a no go. The tranny for the 6.9-7.3 has to be just that, from a 6.9 or 7.3. The tranny from the early powerstrokes will work also. The clutch peddel, clutch master and slave cylinders can come from a gasser though.
Old Sep 9, 2010 | 09:28 PM
jg96powerstroker
yeah its a 7.3 as well it has an ats turbo i put on it, it just a reg cab f250 and has seen better days, the 93 i wanna do the swap on is a crew cab, f350 it was a single wheel but i barrowed the frontend for my 96 f250 crew, so i made it a dully, just wanted a 5 speed auto kida scare me you no. thanks a lot with your help
Old Sep 9, 2010 | 09:39 PM
farmert's Avatar
farmert
Probably need add that both trucks need to have the same drive train 4X4 or 4X2. Either tranny will fit, but the tail shafts are different.
Old Sep 9, 2010 | 09:56 PM
jg96powerstroker
yeah got you there, they are both 4x4. hey on my 96 crew would doing a swap like this be harder on it with all its comp and all??? i love my manuals just scared 2 throw 2 much powwer 2 an auto. and this truck is getting up ther in power and troqe
