Modular V10 (6.8l)
Stumped
Old Sep 9, 2010 | 05:47 PM
bigjp's Avatar
bigjp
Stumped
ok guys here it is. i got a smell of anyi-freeze in the cab when i turn on the a/c and or heater. first thought heater core but the inside of the cab isn't wet anywhere and nothing is leaking from the engine compartment. Level is full and trucks not running hot at all. Thanks guys
Old Sep 9, 2010 | 08:02 PM
Zedrive's Avatar
Zedrive
Recently my heater core sprung a leak there, were no obvious wet spots.
I could only smell the sweet scent of coolant.
Swapped out the core and all things good.
Old Sep 9, 2010 | 10:48 PM
Mr Hanky's Avatar
Mr Hanky
Keep in mind that the heater box vent tube can get plugged therefore no leak under the truck and you may not have lost enough fluid to be noticeable....If you have the sweet smell of antifreeze inside the truck it is generally a heater core....You could always have a local shop put coolant dye into the system for you and run it a week or so and then check things out with a black light....
Old Sep 10, 2010 | 09:37 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Definitely sounds like the heater core is starting to weep. However, I'd still check everything else you can think of. The stuff can evaporate if the leak isn't big, and that smell you smell is the evaporation.
Old Sep 10, 2010 | 08:16 PM
Fordfanatic4life's Avatar
Fordfanatic4life
i bet the heater core is teh suspect..
while you might not have a wet carpet yet i bet its coming soon..
