v10 idle?
Old Sep 9, 2010 | 04:07 PM
speed4x4's Avatar
speed4x4
v10 idle?
Hey peeps!!new to the sight,ive got a small question.ive got a 2000 ex v10 it has small putt putt sound at idle,what do you guys think it could be.
Old Sep 9, 2010 | 04:26 PM
jh818's Avatar
jh818
Did you eat refried beans? j/k
Is it a constant sputter or every now and then a putt putt?
Old Sep 9, 2010 | 04:49 PM
tdappleman's Avatar
tdappleman
Does any vibration go with the sound? How many miles?
Old Sep 9, 2010 | 08:29 PM
speed4x4's Avatar
speed4x4
v10 idle
Its got 125,000 mls,the putt putt sound is just at idle but then stops as soon as you give it gas,also once you get up to speed and high gear it sputters or shakes a little then when given gas and it drops in low gear it stops
Old Sep 9, 2010 | 08:47 PM
speed4x4's Avatar
speed4x4
125,000mls,the sound is only at idle but when given gas it stops,also when in high gear it does it but when given gas to drop in a lower gear it stops
Old Sep 9, 2010 | 10:35 PM
wallz's Avatar
wallz
Have you had any one read any codes? Almost sounds like a slight miss being at different elms. You might want to check the boots that are under the COPS.
Do you know when the fuel filter was last changed? And did this just start happening or has it been going on for a while?
Old Sep 9, 2010 | 10:40 PM
jh818's Avatar
jh818
Sounds like it only happens at low RPMs.
Change your air filter? Bad IAC valve? Injectors need cleaning? Throttle body need cleaning? Throttle position sensor bad? Need new spark plugs?
Can't really say without seeing and hearing it. Does it sound like it's about to stall when it putt, putts?
Old Sep 9, 2010 | 10:44 PM
jh818's Avatar
jh818
Gounding out and arc-ing happens more often with higher RPMs with load, but it could happen at idling and low RPMs as well. Hmmm....I think it's due for a tune up.
Old Sep 10, 2010 | 10:20 PM
speed4x4's Avatar
speed4x4
Thanks for the help,guess i will try the tune up first.i just purchased the beast couple of days ago,hopefully a tune up will take care of it.
Blue Rebel
Nov 1, 2011 11:31 AM
hoxiii
Exhaust Systems
Feb 9, 2008 03:56 PM
bigblock427
17
Apr 11, 2007 08:51 PM
FordBoypete
Jan 6, 2004 06:31 AM
wooddy
Aug 27, 2002 08:22 AM
