Quick EEC IV question
Old Sep 9, 2010 | 01:13 PM
robprime's Avatar
robprime
Hey guys,
Am looking for a mass air computer that will run a 5.0 or 5.8 and an E4OD.
I found a couple of F5TF 12A650-JB (WAY1) units but I'm not sure if they are mass air with sequential injection.
The line on the sticker above where it says F5TF etc says:
EECIV EFI-SMD221
Is this correct?
The speed density PCM's that I have all say EFI-SDxxx and I was thinking, for some reason, that the MAF units would say EFI-MAFxxx.
This is supposed to be a '95 Bronco 5.0/E4OD Federal emissions unit.
Does that make a difference as to being sequential or maybe emissions standards?
As always, I'll appreciate anybodies input,
Rob
Old Sep 9, 2010 | 01:32 PM
ymeski56's Avatar
ymeski56
Der Postmeister
All MAF ECU's are sequential injection.
Old Sep 9, 2010 | 02:04 PM
robprime's Avatar
robprime
OK,
Well, I guess I'll go for it. They're pretty cheap used.
I want to take the motor from the Ranger in my sig and put it in my FlareSide but keep an EFI/auto setup.
I'm hoping that the factory intakes are up to it. It's not a high compression engine, ~9:1
Probably makes a bit over 300 hp and needs 600 cfm to run good.
As long as the computer is a MAF and can adjust to the new demands. I looked at the Quarterhorse tuner that Conansky has mentioned and it looks affordable and the learning curve doesn't look as bad as something like Megasquirt (whew!).
Tho I'd still like to run some LS-2 coil packs if I can get them to work with the EEC-IV. I'd need to interface that with some kind of driver board. Have to look into that.
Thanks,
Rob
Old Sep 9, 2010 | 02:20 PM
ymeski56's Avatar
ymeski56
Der Postmeister
Originally Posted by robprime
OK,
Thanks,
Rob
I't's capable of 300 hp anyway. I'd keep it simple & upgrade the distributor system you have. Then just manually bump your base time. The ECU will take it from there. My 87' 302 runs a .056 gap that's side gapped on top of that (stock is .044). 16BTDC base timing. 87 octane (I do run 89 octane on hard road trips (Longer & faster than usual).
See link:FullSizeBronco.com - 78 - 96 Ford Bronco offroad club, forums, tech, installs
If you just can't help yourself, here's the source for your fix. These guy's stuff rocks!:http://www.performancedistributors.com/index.html
Old Sep 9, 2010 | 04:37 PM
Conanski's Avatar
Conanski
The data I have says that is a 5.0/E4OD MAF EEC so you should be good.
Old Sep 10, 2010 | 08:13 AM
93_flareside's Avatar
93_flareside
According to (Ford Fuel Injection EEC Program Codes) what I've read, and understood it should be correct. I hope, because I just picked up the exact same ecu for my MAF conversion. Haven't purchased my programmer just yet, next on the list thou.
Old Sep 11, 2010 | 01:56 PM
robprime's Avatar
robprime
Yeah, I saw that on FFI also, but I like to see more than one info source. After a bit more searching I did find a reference to this PCM on one of the Bronco sites and the guy talked about it like it was a MAF so I guess we're good.
I also went to the QuarterHorse site to see if it was referred to directly but didn't see it. From there I linked to the EECTuner site and there was mention there on the WAY1, and mention of being able to tune the E4OD also, even sort of stating that there were 'definitions' for that.
I'm not quite up on the definition thing and was going to spend today asking some questions there, but the site seems to be down.
From what I could gather these EEC IV's are seriously programable with the latest tools but are somewhat complicated to set up right. And there are hundreds, it seems, of different factory setups.
Generally speaking, tho, it seems that if the box has the physical hardware to perform a certain function, then you might be able to tune it for your application, whatever it's code might be.
For instance, a box that is built for an SD motor will never be able to run MAF because some of the needed components are simply not present on the circuit board. I would assume that the manual vs auto tranny thing would be like that also.
Also there seems to be a bit of year specificity. It seems that Ford did a serious overhaul/update of the '94 and '95 EEC IV's before switching to EEC V in '96 and changed a bunch of stuff. A 'softer' engine tune was referred to in the later units and also a new type of EGR sensor/valve used that caused running/tune problems.
I really haven't explored all that thoroughly yet, being mainly concerned at this point with obtaining a suitable box to get started with. These WAY1 units are '95 models, tho, for whatever that's worth.
Rob
Old Sep 11, 2010 | 05:42 PM
ymeski56's Avatar
ymeski56
Der Postmeister
Rob
Conanski has always been a very reliable source. If we can't trust him, we're all pooched!
Old Sep 11, 2010 | 07:24 PM
robprime's Avatar
robprime
I didn't mean to imply that at all. Paul knows his stuff. All the longtimers here know their stuff, which is why I always come here to talk about stuff. I just believe in being thorough. Sometime searches on the net have many hits all referring to the same source. FFI is widely referenced when talking about our old Fords.
Rob
Old Sep 11, 2010 | 07:32 PM
ymeski56's Avatar
ymeski56
Der Postmeister
Rob
Yep, the older they get, the harder it gets.
