just some questions
Old Sep 9, 2010 | 08:56 AM
97western haulin's Avatar
97western haulin
just some questions
i've seen on here a few things about a cali model for our engines. what is that and how do you know if yours is one.
is there any real gain in shimming your FPR, and what should the fuel pressure be setting around so if i do i dont blow anything.
and i have recently discovered fuel inside the valley i cant tell where its leaking from yet, i'm going to get int there and clean out the valley so i can see where its leaking from, but suggestions as to where and how to fix it would be greatly appreciated.
thanks
Old Sep 9, 2010 | 10:14 AM
chicagodragon's Avatar
chicagodragon
there is a sticker on the pass side valve cover that will tell you if it is a cali model. also, the fuel pump looks like a flying saucer. see the disc under the turbo?...
Old Sep 9, 2010 | 10:27 AM
Brown Falcon's Avatar
Brown Falcon
If you don't have a cali model stock fuel pressure is between 45-55psi. Optimal is about 65-75psi, but you do NOT want it over 80psi at idle.
70psi is about perfect.
Old Sep 9, 2010 | 06:04 PM
97western haulin
ok. thanks.
do you suggest that its the fuel pump that is leaking?
Old Sep 9, 2010 | 06:15 PM
427 fordman's Avatar
427 fordman
Like you said, could be. Could also be the filter housing or a fuel line. Probably gonna do just what you said and clean it out to find out for sure where its coming from.
Old Sep 9, 2010 | 06:36 PM
rideracelivemx7's Avatar
rideracelivemx7
cali engines also have larrger, 120cc split shot injectors vs the stock 49 state 90cc single shot injectors. makes a little difference in the git up
you could have one of the old fuel lines cracked from heat and weaping, of the fuel pump could leak out the weaphole under the bajo bolt. best way is to clean up and watch were it pools from.
i myself have come to the conclusion on a diesel, if its not leaking, something is wrong LOL
Old Sep 9, 2010 | 07:34 PM
97western haulin
i like that conclusion. haha i just fixed a leak in hose on my rear fuel tank. ha i'll clean it out see whats going on and let yall know what it is once i get it fixed.
is that sticker te sticker for the cali model??? and why is it different horse power at different rpms between the f-sereis and the e-
series
Old Sep 11, 2010 | 06:02 PM
97western haulin
its the vaccum switch ont he side of the fuel bowl. tommorrow it gets replaced.
Old Sep 11, 2010 | 06:05 PM
Copedawg's Avatar
Copedawg
Remember to start early, NFL starts at 1pm est tomorrow! Good luck and let us know how it went.
Old Sep 11, 2010 | 07:18 PM
97western haulin
haha definitly. i saw on here something about it can be replaced with a 1/8th in NPT plug. i looked on home depot's website and searched it and it came up as an air hose attachment. is that right and if its not where can i get one of those plugs?
Old Sep 12, 2010 | 06:38 AM
427 fordman
https://www.ford-trucks.com/forums/9...eak-fixes.html
See if that helps you any. Good writeup for fuel bowl fixes.
Old Sep 13, 2010 | 08:04 PM
97western haulin
it was the vacuum swith/ fuel restriction sensor. i love simple fixes. and it was done well before football started haha
LSO1123
Mar 18, 2013 05:06 PM
spongecop
Nov 17, 2012 11:46 AM
FireHawk4
Oct 20, 2012 11:24 AM
Chorizo520
Mar 25, 2007 11:25 PM
Robbgt
23
Nov 9, 2006 10:41 PM
