Last try
Old Oct 13, 2010 | 07:47 AM
rla2005's Avatar
rla2005
The last time I checked my TPS I found the best results by stripping the insulation off the wires to make it easier to attach my meter leads. Some have reported good results using pins inserted in the wires. Once attached, turn the ignition key to the ON position. When finished be sure to use good tape to re-insulate the wires.
Old Oct 13, 2010 | 05:20 PM
EPNCSU2006's Avatar
EPNCSU2006
I recommend slipping the meter probes beside the wires through the rubber seal into the connector instead of taking off or piercing the insulation.
Old Oct 14, 2010 | 03:50 AM
lupin398's Avatar
lupin398
I did slip them in the rubber seal, but i cannot get a reading at idle, if I connect them and turn on the voltmeter, it's like a killswitch, if i turn on the voltmeter and plug them in when they make a pos and neg connnection it's like a killswitch,
Old Oct 14, 2010 | 04:51 AM
EPNCSU2006's Avatar
EPNCSU2006
I'd just test with the engine off - the readings should be the same.
winginit
70
Nov 9, 2016 11:15 PM
EHC112
Aug 25, 2009 12:25 PM
oldstylefseries
Mar 18, 2005 09:19 AM
SHOpar
1983 - 2012 Ranger & B-Series
Mar 31, 2003 08:59 PM
heathdaily
Oct 16, 2002 02:11 AM
