M5OD hydraulic system behaving oddly
Old Sep 8, 2010 | 09:00 PM
732t37's Avatar
732t37
1991 F150, EFI 300 I6, M5OD trans w/ concentric slave- trans is POS, but I digress. Anyway, I've always had issues with the clutch not disengaging for unknown reasons. At first I had the aluminum frame for the pedal replaced (it WAS bad, egg shaped hole), and up until that point the slave had never leaked a drop. Leaked like a sieve afterwards. I drive in the big city a lot, so no clutch is really not doable, although I've tried (good story for another time). I have yet to hear of someone who is a fan of the concentric cylinder setup, but any thoughts folks?
Old Sep 29, 2010 | 08:40 PM
732t37's Avatar
732t37
Turns out this was caused by the previous owner not tightening all the bolts on the pressure plate. I replaced the entire clutch system from my shoe to the flywheel. I would recommend that the quick connect be cut off from the new hose and replaced with the master cylinder fitting from the old one. This way, the quick connect, which is NOT built Ford tough and can only be connected 2 or 3 times, will not explode and need to be replaced from inside the bellhousing (this happened to me). Heat the fitting, not the line, and be sure to check for blockages with a piece of wire, before actually installing the line.
