Radiator connection question
Old Sep 8, 2010 | 07:05 PM
kpjr's Avatar
kpjr
So my radiator finally bit the dust and am now getting to put it in. I ran into a little snapfoo with the new radiator. I have two copper fittings that I have no idea what they are for and if I can leave them as is. To explain, I am providing a picture of the said items in question.
I bought this radiator at oreilly's today. I called them and they are clueless to what I am talking about. Even showing them, they were still clueless. I have a smaller radiator in front of my radiator and am assuming that is my oil or transmission cooler.
'89 F-250 4x4 7.3L
So again, my questions are:
1. Oil/Transmission Cooler??
2. Can I leave them uncapped?
The Radiator @ O'Reilly's website
Old Sep 8, 2010 | 07:30 PM
wreckinball's Avatar
wreckinball
most times they become a oil cooler but they are the trans cooler hookups.
Old Sep 8, 2010 | 07:35 PM
kpjr's Avatar
kpjr
Cool, thanks! Right now I am just trying to get her back on the road. I can probably make it an oil cooler at another date & time. Although is the processes all that hard to make it into an oil cooler? Can I leave them as is with those rubber caps on or do I need to cap them off before I fill the rad with juice??
Old Sep 8, 2010 | 09:26 PM
Dave Sponaugle's Avatar
Dave Sponaugle
You can leave the caps on there, should be no pressure and no coolant in them.
The stock oil cooler does a good enough job that running the oil through that cooler would just be a restriction.
All oil from the oil pump goes out through the side of the block into the stock oil cooler, then to the oil filter before it ever goes in the engine oil passages.
Old Sep 8, 2010 | 10:34 PM
LCAM-01XA's Avatar
LCAM-01XA
What Dave said, do not make this into an oil cooler. It is a transmission cooler for trucks with automatic transmissions, but works good as a fuel heater as well (if you run stuff like WMO and such that should be heated before it reaches the IP). If you have an automatic trans then run this cooler between the trans and the external cooler you have now.
Old Sep 8, 2010 | 10:36 PM
kpjr's Avatar
kpjr
Awesome! I have a manual so no worries about the trans cooler there. Thanks again!!
Old Sep 9, 2010 | 09:58 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Make sure you plug them to keep crap out of them for possible later use ...
-Enjoy
fh : )_~
PEI
Feb 17, 2014 05:02 AM
Vijay
25
Jan 8, 2014 12:41 AM
Cowboy65
Sep 8, 2013 12:12 AM
michbol
22
Dec 31, 2011 04:07 PM
timmygyu
1978 - 1996 Big Bronco
Apr 13, 2011 01:21 PM
