making the tach work
Old Sep 8, 2010 | 02:56 PM
75Three90's Avatar
75Three90
OK i didnt have a tach in my 1993 5.0 4x4 and i wanted one i dug through my pile of old parts and found one from a diesel hooked it up and all the gagues worked except for the tack how do i make the tach work?
Old Sep 8, 2010 | 04:49 PM
rla2005's Avatar
rla2005
The tach from the diesel will not work in your gas engine equipped truck (or vice versa). The diesel tach gets it's signal from the fuel pump timing gear. The gas engine tach gets it's signal from the negative side of the coil. Two different animals.
Old Sep 8, 2010 | 05:33 PM
fordyduty's Avatar
fordyduty
if you decide to hook up an aftermarket tach. then the green wire of the tach will connect to the green wire at the coil.
Old Sep 8, 2010 | 08:01 PM
75Three90's Avatar
75Three90
i figured it could work cause the tach jumps it just doesnt work correctly
Aune163rd
Dec 13, 2014 08:02 AM
quesey
1978 - 1996 Big Bronco
Dec 26, 2013 06:10 PM
ALedbetter1
Jun 26, 2013 05:14 PM
Old Hickory
Feb 26, 2011 08:39 AM
IDfordguy
Sep 26, 2005 01:00 PM
