Sponsored by: Real Truck
no tail lights
Old Sep 8, 2010 | 11:29 AM
star's Avatar
star
no tail lights
Dont know what went wrong "I have no tail lights,no over-head lights,no insturment lights,fog lights,just head lights are working on a 02 F-350 SD 4x4,7.3..all fuses are good ..what else to check ? ..
Old Sep 8, 2010 | 06:02 PM
riggz's Avatar
riggz
You SURE ALL all the fuses are good? Many times a fuse will look good, but actually be bad. Maybe a bad relay?
How did it happen? Did it just happen driving down the road? When you went to turn on the lights? After doing any recent work?
Old Sep 9, 2010 | 08:50 AM
star's Avatar
star
I had some work done a few months ago,maybe a ground came loose ..
Old Sep 9, 2010 | 10:14 AM
thomabb's Avatar
thomabb
Do you have DRL? When you say no tail lights, what about brake and reverse lights?
Old Sep 9, 2010 | 10:15 AM
star's Avatar
star
I do have back-up lights ..no tail lights
Old Sep 9, 2010 | 10:16 AM
star's Avatar
star
Which relay will i BE LOOKING FOR ?
Old Sep 9, 2010 | 10:32 AM
thomabb's Avatar
thomabb
Do you have daytime running lights on your truck?
Pop the light switch out of the dash and see if you are getting juice to the switch. I think it is a tan/white wire. It should be hot with the key off and the switch in the off position.
Old Sep 9, 2010 | 10:34 AM
star's Avatar
star
Ill check after work ..Thanks
Old Sep 10, 2010 | 06:28 PM
riggz's Avatar
riggz
What kind of work? Where on the truck was the work done?
