Looking at a 2008 F350 6.4
#34
#36
#37
Thanks, Sam...that makes sense from what I saw. I can't see what holds them on, but you're right...it does appear that they are removable. Very bizarre....maybe someone had some fancy schmancy tips on there? LOL
#39
I'd have the dealer restore the exhaust as designed. You want it to come out all the way so that it cools down enough during the regen process.
As far as testing the nitrates, there is a bulletiin that came out, don't see it in the tech folder, talks about the nitrates. Will get it later tonight and post it.
#40
#41
#42
#43
#44
Check coolant nitrite strength using the 3-Way Antifreeze Test Strip kit Rotunda # 328-00001 to determine if additive is required. If the nitrite strength is between 800 ppm & 300 ppm add 32 fl. oz. (946 mL) of Supplemental Coolant Additive Motorcraft VC-8 or equivalent. If nitrite strength is below 300 ppm flush & refill engine coolant (refer to Motorcraft Premium Gold Engine Coolant Change Record) – Do not add Supplemental Coolant Additive if flush & refill is required.
#45
it says
