05 f150 shift problems at WOT
Old Sep 8, 2010 | 01:53 AM
Cainrotty's Avatar
Cainrotty
I recently changed plugs and trans fliud change also. I had to replace the actuator for the intake last year. My fuel mileage has went from
16.5 to 12.5 in the city and at wide open throttle it feels loaded up and shifts hard from first to second and won't shift out of third. It tries but it won't. Seems to shift fine under normal throttle condition. Any thoughts would help
thanks
Shawn
Old Sep 8, 2010 | 03:56 PM
LxMan1's Avatar
LxMan1
You might get better replied in this forum.. You might check to make sure you didn't knock any vacuum lines off when changing the plugs and you may try cleaning the MAF sensor.
Old Sep 8, 2010 | 07:47 PM
Greg B's Avatar
Greg B
Double check and make sure all of your vacuum and electrical connections are good from the plug change. If so, I would suspect possibly an injector problem. The 04 and 05's did have some injector issues with the injector sticking open or not closing all the way and making a rich condition. A code scan might show this.
FERdter
Dec 8, 2016 07:20 PM
Highcountry30
Nov 6, 2016 11:36 PM
Kyle Stine
1978 - 1996 Big Bronco
Jan 31, 2016 11:59 AM
manram
13
Feb 5, 2015 03:35 PM
406angler
Mar 3, 2014 04:49 PM
