Sponsored by: Real Truck
trans not going into overdrive?
Old Feb 18, 2003 | 08:23 PM
icebreaker88's Avatar
icebreaker88
I HAVE A 95 PSD, E4OD AFTER I BOUGHT IT I NOTICED THE BUTTON ON THE SHIFTER WAS NOT WORKING ALL THE TIME. I HAD TO HIT IT A COUPLE OF TIMES BEFORE THE LIGHT CAME ON.
THEN THE BUTTON QUIT WORKING COMPLETLY. BUT THE TRANS SHIFTED FINE INTO ALL GEARS(INCLUDING OD)
NOW WHILE I WAS DRIVING IT WOULD NOT GO INTO OVERDRIVE AND THE BUTTON DOES NOT WORK AT ALL.
Old Feb 18, 2003 | 09:28 PM
bddo's Avatar
bddo
icebreaker,
I'm not sure, but it sounds like maybe the O/D switch is bad... IF it's not too hard to remove, then it might be worth testing the switch first.
Sorry I couldn't be more help!!!
Old Feb 19, 2003 | 07:13 AM
jetjock16's Avatar
jetjock16
mine just altogether quite one day, the button and the OD, it is still under warrenty so i took it in, the dealer fixed it in about 1/2 hour, they said some plug had come apart. Might try followin the wires up under the steering wheel??
good luck
Jetjock16
