Where Can I buy reasonable yet Very Strong Leaf Hangers for the rear of my 1993.5 Ford F250 7.3 IDI 4x4 Truck. I found some on RockAuto Parts for $19.95 for 1 I was wondering if that was a cheap brand or thats the going price. I need all 4 in the rear! Recommendations are very welcome!!!
Thanks for your Time!
Originally Posted by charles09
Will these work? and are all 4 on the rear alike? I want to go ahead and change out the whole rear!
thats what i used to replace one of mine(rear of rear drivers side.)
its good.
thats where i got it too.
was just starting to get a little thin/slight rust hole started even.
i haul heavy often,so i replaced it before it got worse.
price was right and the part looks stock.probably made at same factory but skips the ford logo imprint at the end hahaha,i dunno.but you never know nowadays.it wouldn't surprise me any.
The rear hangers are all the same between different models so you're fine with whatever you find there.
The front of rear are different on F250's and F350's because they have a 3" wide spring. You can find them at jeff's bronco graveyard or autoandtrucksprings.com, and be forewarned they will run you about $130 for the pair.
