HELP! High Pressure Oil Pump
Old Sep 7, 2010 | 07:20 PM
JandS's Avatar
JandS
I am looking for a diagram/instructions for installing the High Pressure Oil Pump. Any help is appreciated! Thank you!
2003 F250 6.0 Super Duty
Old Sep 8, 2010 | 07:43 AM
dkhollins's Avatar
dkhollins
If you want the online version of the service manual, check out ALLDATAdiy.com :: Leading Source of Diagnostic and Repair Information and you can purchase the online version of your service manual for $25. This should give you all the information you need to do the job.
If you run into any specific questions, let me know because I just finished this job on my truck a couple weeks ago.
Old Oct 6, 2011 | 10:57 AM
rockstar69's Avatar
rockstar69
Post HIGH OIL PRESSURE PUMP
I have to do the same on my 2003 6.0 did you have to have any special tools.How long did it take you? Ford quoted me 13hrs....plus part.These on line manuel was it complete enough with pixs or just texts
Old Oct 6, 2011 | 11:02 AM
dkhollins's Avatar
dkhollins
Special tools....just the tool to remove the radiator fan and the oil line for oil cooler. Other than that the basic and a nice torque wrench for the intake and other parts.
I have both the Ford Paper Manual (Books) and the online and the online version is just as complete. So either would work....although I do prefer to have the books in the garage with me so I can finger through them while doing the job.
Good luck!
Old Oct 6, 2011 | 11:10 AM
NewToDiesels's Avatar
NewToDiesels
I didn't remove my fan to do my HPOP. No special tools required. ^^^^^ Just a torque wrench as previously mentioned. I'm not a mechanic, just a guy that likes to save money and learn new things... Took me a day to do mine. A full Saturday. I had previously installed a new EGR cooler and Bulletprood oil cooler and that took me two weekends.
Old Oct 6, 2011 | 04:22 PM
npccpartsman's Avatar
npccpartsman
YUP--no reason at all to remove the radiator or fan. The two "hidden" intake bolts at the extreme front of the intake inside the fan stator can be removed without removing anything else. They require a 15mm socket BTW.
Clarkcoplan
Jan 24, 2016 09:26 PM
Lance Empey
Jun 9, 2015 12:43 AM
Viper6913
Apr 25, 2015 11:56 AM
kmt5204
Dec 23, 2014 10:39 AM
genscripter
Nov 26, 2013 01:22 PM
