Automatic C6 tranny will not shift when in D I can shift manually from 1 to 2 but when back to D for 3rd, it's like D is 1st only. I've replaced the vacuum mod, haven't adjusted it, replaced fluid, pan gasket, filter. If I start in D, it winds up and will not shift, if I let off the gas and back on, it just revs as if its in neutral until it slows down enough to go back to 1st.
Fluid was clean, not burnt, no metal in the pan.. I replaced the VSS and Vac Mod all with the same result. I am wondering if I have a linkage problem or possible valve problem.
Stuart, Thanks! I will check for good vacuum at the mod, Reasonably certain the KD rod has a return spring, but I'm not sure it's setup correctly either. I'll check both of these and test run!
You should have around 18in Hg vacuum at the modulator on the trans.
If a diesel and you do not have that amount of vacuum then the vacuum pump may be bad or the VRV on the injector pump may be bad.
However check the condition of the pipe from trans to engine first if vacuum is bad.
Thanks guys for your valued and much appreciated input. It was a vacuum problem. I had none at the Modulator and once I corrected that, this thing runs like a dream. Few more little cosmetic things and all will be well.
