Holy huge tachometer that looks good. Where'd you go for the tie rod?
The Dash is filled with gauges and I like the top mounted tach vibe. I have always done a lot of drag racing and the RPM shift light will be installed later.
I don't recall where I got the tie rod from but two or three of the common sources sell them. Probably anyone who sells Toyota Box set ups. It also has the larger tie rod ends. With the power box and wider front tires that will eventually be there, I want to ensure things are robust.
Looking good! You've made way more progress this year than I have. I'll have a cold one in your honor!
(I do have a helpful tip for you on picture taking. The next time you want to take a pic of the truck and you really want it to come out looking good......can you step backwards about 30 paces and maybe 20 paces to the right....LOL!!!!!)
