"Freaking Guages"
Old Sep 6, 2010 | 08:08 PM
fanofford's Avatar
fanofford
"Freaking Guages"
I am having an issue with my 2004 Explorer that i hope someone can help with. Every time I start the truck the guages bottom out and make a clicking noise as they seem to bounce off of the peg. This goes on for about ten seconds and then stops.Each time this happens the trip mileage resets to 0. The battery is not in the best of shape but i don't have the money to replace it right now. Could the condition of the battery be to blame? I did a search on this topic and came up empty. Anyone?
Old Sep 6, 2010 | 09:37 PM
shorod's Avatar
shorod
I would certainly suggest you change the battery before worrying too much about this issue.
Think of it this way, a new battery will probably cost you about the same price as the tow bill when it leaves you stranded.
-Rod
Old Sep 6, 2010 | 09:43 PM
esaycho's Avatar
esaycho
Put it this way, All the E-450 trucks I have at u-haul, battery is dead and I crank it, soon as i release the key it does this. And on my 02 explorer, would do this when I reconnected the battery and turned the key on. So I would definitely point to the battery for this, and with colder temps coming, it is going to leave you stranded
Old Sep 29, 2010 | 07:28 PM
chasd's Avatar
chasd
Funny but this just happened to me after being gone for a month. Tried to start the '02 but it wouldn't turn over. I guess the "security" system drained the bat in that time frame. Put the battery on a charger but it wouldn't hold a charge. It was a Checker 96 month bat that failed in 60 months.
Old Sep 29, 2010 | 08:19 PM
steve(ill)'s Avatar
steve(ill)
problem is common with bar batteries.... also i havenot heard of 96 month batteries.. most are pretty well shot at 60-70 months.
Old Sep 30, 2010 | 01:11 PM
chasd's Avatar
chasd
I'd never seen a 96 mo battery either but as I remember it was a special sale Checker (now O'Reily) had when my OEM battery failed. It's my belief that battery warranties are set to exceed the actual expected battery life so the owner has a bit of warranty left and is "forced" to buy the new one from the same source or lose the little bit of warranty value left on the failed battery. Yes that's a cynical view but it is based on 50 years of experience!!!
